There are no idle screws. Idle is controlled by the computer via the idle air control valve. All other sensors and vacuum hoses need to be working and in good condition. IA valve is attached to the throttle body.There are no idle screws. Idle is controlled by the computer via the idle air control valve. All other sensors and vacuum hoses need to be working and in good condition. IA valve is attached to the throttle body.
You can't post conmments that contain an email address.
Like answer #1, when I bought my 1993 Jeep Cherokee, one of the first things I ended up doing was go to & join the
cherokeeforum.com, i.e. cherokee-forum-dot-com....
I've found that whenever I need advise, or answers to any questions with my vehicles, I look for the forum for that vehicle. 99.9% of the time the folks in the forums give you honest answers..... I even subscribe to a few YouTube Channels, like the one for my 93 Cherokee. That guy is not only smart when it comes to 1990s-2000s Jeep Cherokee's/XJs, he's always doing some sort of repair or modification to one of his Cherokee's or Grand Cherokee's..... Hope this helps all you Jeep XJ Folks out there....
It likely has EFI (electronic fuel injection) and an idle air control valve that regulate idle speed. They can get gummed and fail to have a fast idle when cold, or get stuck the other way, and have a too fast idle all the or regularly take its time slowing down after you take your foot off the gas. An engine temp sensor can also cause a lingering high idle if it reports the engine as still being cold after warm up.
The idle speed adjustment on most fuel injected vehicles is located in a recessed hole near the throttle butterfly on the intake manifold(sometimes with a plug in it). Screwing out the adjusting screw should increase idle speed.
The idle air control valve is located on the back of the throttle body. It has an oval electrical connector and two torx screws holding it in. Unplug the connector, remove the two screws then lightly tap the body with a soft faced mallet to loosen it from the body. Once you have it out and prior to installing a new valve clean the seat inside the throttle body where the idle control fits. This must be very clean! Installation is in the reverse order. To save some cash, pull the valve out and clean it with throttle body cleaner, this usually fixes the problem for quite a while. Good luck and hope this helps.
If you have the owner's manual look up fuses in the index, good illustration. If you don't, I do. It shows a relay and a 15 amp fuse. Look at the passenger kick panel, pull the cover, and it is #2 fuse (second from the top on the left) The see the relay you may have to pull the panel (two screws and a clip) the relay is the third cavity down, third row from the firewal side.
Let me know if this works for you?
its not real bad. it is located on the back side of the throttle body and is held in by 2 torx head screws. they are t 25 screws. remove them and slide the ais motor out and install the new one. when you start the vehicle up it may idle high for a while til the computer actually gains control
