Panasonic Lumix DMC-FS4 Digital Camera Logo
Posted on May 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I locked my card, not purposely and I don't know how to unlock it. Panasonic dmc fs4
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Panasonic Master 102,366 Answers
  • Posted on May 17, 2011
Panasonic Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443216
Points
622693
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Won't load to computer reads camera not card
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101
1helpful
2answers
I want to download the user manual for my lumix dmczs5
You can download it from the support section of the Panasonic website.
1helpful
The memory card is locked
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If that doesn't do it, try another card.
6helpful
2answers
I have a DMC-FS42 and the memory card is locked how do I unlock it Thank you!
The memory card may be physically locked. If you remove the memory card from the camera look at the side of the card. There is a small lock that can be slid up and down on the side of the card. Make sure the lock is off. If you cannot tell which direction is locked switch it and then try it in the camera.
If you have pictures on the card try to download them with a card reader first then attempt to format the card in the camera by going into the camera menu.
4helpful
4answers
How to charge Panasonic lumix DMC-FS4
hello there use your USB cable for charging your camera battery. No need to take out the battery from camera. Some Tips.
  • You may choose our Smart Charger (0.5A,UL listed) for 3.7 V Li-Ion battery Pack to recharge this battery pack. Must charge the battery pack with correct polarity. The estimated charging time is 2.76 hours .
  • You may connect two 3.6v 920 mah pack in either series or parallel connection for making a higher voltage and higher capacity pack.
  • Hope you have those staff with your camera. use that for charging. Follow the link.
    http://www.batteryspace.com/smartcharger05afor37vli-ionpolymerrechargeablebatterypack--ceullisted.aspx
    Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
    5helpful
    2answers
    My memory card is locked how can i unlock it??
    SD and SDHC cards have a slide switch along one edge. The position furthest from the contacts lock the card, the position nearest the contacts unlocks it. Try sliding the switch fully away from the contacts, then fully toward the contacts. If that doesn't solve it, try a different card.
    Got a Lumix DMC FS4. LCD screen has been broken
    No it cannot be fixed by you because it has to be done with at most care.Only a skilled technician can do it.Please contact your nearest service center for a genuine accessory.
    2helpful
    1helpful
    DMC-FS4 problem with getting downloaded motion pucture to run in
    It may be that the format the Lumix creates is not compatible with Picassa 3. My videos do not play well on my PC running XP but are amazing on my Macbook OS X.
    Top Panasonic Cameras Experts
    ZJ Limited
    ZJ Limited
    Are you a Panasonic Camera Expert? Answer questions, earn points and help others
