Question about Acer Aspire 5002WLMi Notebook
Acer Aspire 5002 Laptop will not stay on
Laptop does not start. When the start button is depressed, the I/O, hard drive and britghtness LED light up momentarily in green and then shut down. The power supply was checked and is working fine. When the PS is plugged in the computer the battery LED lights up in amber color.
Is this an indication of a bad battery? Isn't the laptop suppose to work when plugged in even if it has a bad battery? Will a bad CMOS battery keep a computer from starting even with the PS plugged in?
  • jibaro Aug 15, 2008
    Thanks for the input. The fan just jiggles when I try to start it and then it shuts down. How do I troubleshoot the fan?
    jibaro
It seems like if the flashing LED's at startup are all you get, and that all happens within a couple of seconds it's probably not a heating issue b/c it wouldn't have time to overheat. You could check it by putting the whole machine in the freezer for an hour or so and trying to start it cold. You'll get at least 30 seconds from it if it were a heat issue - long enough to get through POST and into bootup before it locks up anyway. I know AMD's run hot, but I think you may be looking at a bad RAM chip (although usually you would get beeps from the bios for that) or a bad PS or a flaky MoBo. If you have two RAM chips - try going down to one. If you have the extra chip available - try a different RAM chip in it altogether. Usually you can hear a fan making noises before it just quits, and if it just quits most people will notice it b/c the laptop runs almost completely silently without a fan.
Posted on Oct 31, 2008
  • 56 Answers
This can be an overheat issue. Either the CPU or the Chipset is overheating. Make sure all your fans are working.
Laptops still turn on with the ac adapter plug in and without a battery plugged in. Nope a bad CMOS battery would give you a warning message on the laptop screen, stating the CMOS battery is low or needs to be replaced.
Also does your battery hold a charge? If so with the battery plug in only (without the ac adapter plugged in) does the laptop do the same thing?
Posted on Aug 15, 2008
  • Joe L.
    Joe L. Aug 15, 2008
    To see if the fan is stuck or jam and won't spin freely. Try this, take a pen or pencil or something that will fit, and try to move the fan. If it doesn't move freely and seems a bit stiff. Then it could be an overheat issue and something on the laptop could have been overheated and burnt out.
6ya staff
SOURCE:
Remove hard drive Acer aspire e1-472 laptop
In that case it is probably under the keyboard.
6 minutes into the video you can see the hdd
how to replace hard drive laptop acer Aspire E1 472 replace RAM
Mar 13, 2015 | Acer Aspire E1-472G-6648 Misty Silver 14"...
On acer aspire laptop screen is grey at startup
1. When you press the power button to turn it on, do you see any thing on screen, It probably should show an ACER logo?
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). If you do see a faint image it could mean your back light is broken.
3. When you press the power button do you get different LED's lighting up on the laptop? IE power LED, hard drive LED?
4. Does your computer give you any random beeps when it starts up?
Please answer these questions and I would be more than happy to work through this with your.
Thanks RCCT
Jan 16, 2014 | Acer Aspire Computers & Internet
How to remove cd/dvd drive on a acer aspire 5003WMLi
Turn the laptop over, on the bottom you will find a screw about 5-6 inches in from the cd-rom drive. The screw will have a little symbol of a CD next to it. If you remove this screw the cd-rom drive should slide right out. Be sure to do this with the laptop turned off, unplugged and with the battery removed.
Sep 19, 2012 | Acer Aspire 5002 Wlci Zl5 - 5000 Series...
Can Acer aspire 5002 support 160GB IDE Harddisk
Yes, it'll support upto 250gb hard disk. For more information about your laptop, click here.
Good luck.
Thanks for using FixYa.
Aug 24, 2010 | Acer Aspire 5002WLMi Notebook
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Replace hard drive acer netbook 8 gig
Back up all info
Insert CD / DVD Win OS into Cd / DVD drive
Shut down laptop / remove battery / depress strat button several times to de-energise system.
Remove tiny screws under the laptop to access HDD, Be very careful prizing off cover so as not to break it.
Remove HDD carefully, you may need to unscrew HDD
Replace with new HDD / replace cover
Start Laptop and depress F1 or F2 to get into bios, alter boot sequence to CD as first boot.
Follow on screen instructions to format HDD / load Windows.
You must have a legit copy of the Windows disc and CD key
Dec 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Help... Acer Aspire 3690 laptop.
My dear friend as I told you that you should change your RAMs it will b ok give me your response on jazib_qurashi2000@yahoo.com
Nov 19, 2009 | Acer Aspire 3690-2196 Notebook
If it's spinning it's working - if it's not - then it's broken.
Aug 15, 2008 | Acer Aspire 5002WLMi Notebook
Acer Aspire 5002WLMi Notebook Logo
153 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
