Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
Posted on Sep 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY BOSCH WASHING MACHINE MODEL WFMC6400UC STOPPED RESPONDING TO THE START BUTTON. IT STARTED INITIALLY AN WITH ERROR MESSAGE. WHEN I TURN IT OFF AND THEN ON. IT WILL START WORKING AGAIN. THEN IT MOVED ON TO ME HAVING TO FIGHT( I MEAN KEEP FIDDLING ) WITH THE START BUTTON FOR IT TO COME ON. FINANLY, THE START BUTTON JUST WILL NOT RESPOND. PLEASE HELP. THANKS FOR THE TIME
richie46
Level 3:
Top Expert:
  • Bosch Master 12,962 Answers
  • Posted on Sep 08, 2017
richie46
Bosch Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946171
Points
58151
What error message did you get? Did you research what the error message indicated? How can you make a repair without knowing what is wrong? Makes no sense.
5 Related Answers
Anonymous
  • 105 Answers
  • Posted on Jan 02, 2008
SOURCE: power to washer is on, but display not responding
maybe door not closing correctly
try a bit of crc in lock to lube otherwise controller shot and brushes worn out in motor
Anonymous
  • 4 Answers
  • Posted on Sep 05, 2008
SOURCE: Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Anonymous
  • 38 Answers
  • Posted on Jul 28, 2009
SOURCE: error code 02 on a newly installed Bosch Nexxt Washing machine
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
Anonymous
  • Posted on Feb 19, 2010
SOURCE: sud message Bosch washing machine
ur using too much soap rinse and spin and use less soapwhen u wash
Testimonial: "thanks-- how do you know how much soap is enough?"
Anonymous
  • 2605 Answers
  • Posted on Mar 29, 2010
SOURCE: Bosch Nexxt Premium WFMC6400UC washer will not
Hi there, In reading your post I'm not sure I know how to approach giving a solution. Would it be possible for you to expand your post and perhaps provide more details ? Does the unit have 120vac going to it ? ( is there any lights in the display ) Does it fill with water ? ( with either hot or cold ) Do you hear the door lock ? ( you should hear a "click" when the lock engages ) Has there been any error code displayed at anytime recently ? As you can see just by saying the "washer will not wash or spin" leaves more questions rather than possible starting places to help move you toward a solution. I will watch for you to reply. Thank you for coming to fixya, I hope we/I can assist you further. Macmarkus :)
1helpful
2answers
BOSCH MAXX CLASSIC E2 error reset, has water and drained, but the machine did not run/spin.
FROM FIXYA
Sanja Salatic NOV 29, 2009
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
Ihave Bosch Maxx 6 e2 error. I tried to reset the machine but it didn't work. What is the problem and what can I do?
To fix you must do a master reset of the washing machine.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
This worked for me
Why won't it start?
Bosch WAS32461GB Washing Machine that will not start
www.how-to-repair.com/.../bosch-was32461gb-washing-machine-that-w...
Mar 31, 2015 - Bosch washing machine Will not start, won't start, Will not open - this is usually due to the machine still having water in it or a door interlock ...
My Bosch Washer Won't Start ' eHow
www.ehow.com > Home
If your Bosch washer does not start, there are a few troubleshooting steps to take before calling for ... Problems with Bosch washing machines that won't spin.
Bosch washer WFMC6400UC won't start - Appliantology.org
appliantology.org > ... > The Laundry Appliance Repair Forum
My Bosch max classic is showing error E2
http://www.fixya.com/support/t3342120-error_code_e2_mean_bosch_maxx
3helpful
During every cycle, I get a "check water tap" message? It stops running and beeps until I press the start button again
Welcome to FixYa.
What happens when you press start again, does it continue on through the cycle or display error again ?
Typically this message indicates the water is shut "off", a hose is "kinked/pinched" or a small screens/strainers inside the fill hoses has become blocked or partially blocked.
If you turn off your water and remove the hoses from both ends, clean out the screens in the hoses and in the valve, that may remedy the issue.
Let me know what you find and we can go from there.
Good luck.
macmarkus :)
72helpful
What does error code E2 mean? I have a Bosch Maxx Classic.
3helpful
2answers
Error code 02 on a newly installed Bosch Nexxt Washing machine
Will not spin
I have an older model that would not spin. We did not have a digital display, so can't help there, but it turned out the bushes on the motor were worn out and needed replacing. Hope this helps.
Bosch Nexxt Premium WFMC6400UC does not start with the following status: Start/Paus light blinking Display says ready Pressing start does not do anything I have done the following: Holiding the Start...
A faulty module or timer/control panel. Unless you are getting some form of error code in the way of flashing lights or otherwise. In which case refer to manual. Good luck.
E02 Code
Faulty heating element, or main eprom is faulty
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
