Vizio M320NV 32 in. HDTV LCD TV Logo
Posted on May 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Visio M320NV LCD TV troubleshooting problem - hit some button while in bed and now using HDMI Side and reset to factory and all it goes on, shows getting data then the message "NotSupport" and cannot find what to reset nor the message in troubleshooting. What is going on?
Anonymous
Level 2:
New Friend:
  • Expert 110 Answers
  • Posted on May 17, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
110
Questions
0
Helped
81597
Points
378
Here is the manual from the vizio website: http://www.vizio.com/documents/downloads/hdtv/M370NV/715M370NV_UM.pdf
Can you provide more info on your problem?
How do I get my Sony universal remote to work with my Visio tv!
On your Visio TV remote control there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. See the TV to see how the HDMI cable is connected from TV to Set Top Box. Now take the other remote control i.e. Sony Universal remote in your hand. Press mute & Select simultaneously. A blue light will blink twice, Immediately release the buttons & enter the code. You have to be extremely fast in doing this.
Following are few codes which you can try:
002, 000, 011, 080, 111, 006, 071, 128, 1904, 925, 0000, 0834, 0810, 1685, 1786, 1032, 1972.
Check the Visio TV manual for the make of your TV & model no & if code is printed. Then contact Visio TV manufacturer or retailer for the Visio TV code to enter & synchronize with the Sony Remote Control.
Sony bravia kdl-40w600b..turns off after switching on..and the red light indicates 8 time..whats the issue..and need to resolve
8 red flashes- main board sp prot, try power reset, update with usb, or replace main logic board
How to service fix phones tablets PCs TVs and tech reviews blog by Tampatec
Factory reset:
https://us.en.kb.sony.com/app/answers/detail/a_id/43126/c/65,66/kw/factory%20reset/session/L3RpbWUvM...
First I unplugged my HDMI cable and powered OFF my router (using wireless).
As soon as HDMI 1 showed on screen, pressed the arrow up button on remote, touched the power button on left rear side (uppermost) button on my TV) and let go of arrow up. TV said RESET and after a min, TV went back to setup screen. Followed Setup onscreen instructions and working OK.
1helpful
2answers
HD worked with HDMI cables on HD Cable Box & ROKU3. Now only get SD transmission. Is it worth repairing?
On a 32' tv the repair probably wouldn't be worth it after labor costs. They're cheaper to replace with a new one and less of a hassle.
I have a 32" visio M320NV LED tv. About 13 months into owning it, colored vertical lines took over the left-hand side of the screen, leaving me incapable of viewing the entire picture. it began with a few...
If you wish to get more details, check this link. Some details about this kind of fault to LCD TVs are given with screen shots. You can compare it to that of your TVs' and can make sure whehter the work can be done by yourserf. If not, contact any service technician http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
3helpful
M320NV SCREEN IS HALF WHITE
tried with re seat the LVDS cable at the t-con board. if can not get with re seat it could be bad t-con board.
1helpful
Does Visio TV, Model No. M320NV, Ser. No. LAQKGYAL 3200084, have a feature enabling the user to turn it on and off at set times. We need a User Manual. Thanks
Here's a link for the manual http://vizio.com/documents/downloads/hdtv/L32/Manual.pdf
As for a scheduler there is none in the tv only a sleep timer which has to be manually set every time. You can set it to turn off in 30 minutes increments up to 120 min. This is in the menu under Special Features-Sleep Timer.
1helpful
My Vizio 42" LCD SV421XVT
U getting a non respones from ur remote or the manual side panel tv controls buttons wright.U already tries resetting it back to factory setting.But the problems still the same.Yes,the tv Tuner signal board is the causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
1helpful
SV470XVT Vizio picture freezes
Hello, This seems more like an interface problem then a board issue. Which interface are you using Component Video, HDMI or , RF(F Connector)? If you are using the RF (F Connector) there might be a problem in the tuner including the RF and IF sections on the circuit board. If you are using HDMI there might be a problem in the HDMI Integrated Circuit If you are using componente video the there might be a problem in the video circuits connected to the RCA jacks of the Component video input. If I were you I would have the take the TV back to the shop and have these items checked out, because board swapping is not the proper thing to do. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
48helpful
4answers
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
1helpful
2answers
LTV-40w1 HDC Westinghouse TV
I had the same issue. I just bought this tv. I went to source on the side of the tv pushed the input button til it went to YPbPr1 and the screen came up. My HD cable box is a little old so I'm using that instead of HDMI. But if your using HDMI just keep hitting that button til you see HDMI and it should work.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
