SOURCE: Kodak easyshare camera not transfering photos
My kodak easyshare camera will not transfer my photos to the computer. Everything is plugged in and the camera is blinking but nothing is happening. Please help. I checked the connections, they are fine.
SOURCE: turns on then automatically shuts of
FIRST CHARGE YOUR BATTERY OVERNIGHT AND THEN REMOVE YOUR BATTERY FOR ABOUT 10 MINS PUT BATTERY BACK YOU HAVE TO ADJUST THE DATE AND TIME AFTER DATE EVERYTHING WILL BE OK BUT IF YOU ARE USING 9 OR HIGHER MEGAPIXEL YOUR BATTERY WILL BE DRAIN IN THREE TO FOUR HOURS.
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
Yes you are. My wife denied that she dropped in the sand but I found a list of photos that she wanted to print on a post-it paper in the cover and it had sand all over the sticky part. Used the pressure air spray to clean the rings and it is back to life. Well It worked but there was some problem during zoom in&out, so I spray the rings while zooming and out and that cleaned it. I hope I don't have to open it to clean the mechanism. Thank you.
Hi.
Enter main menu, scroll down to "Setup Menu" and then navigate to "FORMAT". Simply format your internal or external memory, and thats it.
