Plug it into a USB port usually located at the front of a computer or if its a laptop it could be on the side once inserted it should install it if it fails to install itself you might have to install it manually
click start control panel administrive tools computer
management device manager scroll down universal serial bus controllers you
could see a yellow question mark? go to the information you want to back up select the information right click?select copy then back to memory stick select then right click?select??paste
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
click start all programs accessories open windows explorer my computer you should see your drive click to open it from there you can save files to it
or select the imformation hold the cursor on then drag it to the memory stick and drop it into it
or select the imformation right?click and send to the memory stick
always remember to click the remove hardware safely before removing it you will see this on the bootom toolbar when you plug it in it should look like a green arrow
if you are using windows 7 just right click on it and select remove
hope this helps
This is a Flash drive, not a Hard drive. If it is plugged into a USB port on your PC or laptop then the computer will automatically load the drivers for it and assign a drive letter - usually E or F (C is the hard drive in the PC, D is usually a DVD drive). This should work with Windows XP, Windows Vista & Windows 7. Other oerating systems may require a driver to be downloaded (if available).
