Meridian M9316 Corded Phone Logo
Posted on May 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the Date and Time displayed? - Meridian M9316 Corded Phone
Anonymous
Level 2:
Scholar:
  • Expert 53 Answers
  • Posted on May 16, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
53
Questions
0
Helped
25851
Points
137
You log into the Phone administrator settings, Go to General, Select Date and Time and correct them for the entire phone system.
To Log Into System Programming:
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
3. Press: NEXT Display will read: "B. General Admin"
4. Press Show
5. Select Date and Time and Press Show Correct Date and Time then press release. Let me know if you have any other questions.
Set clock on computer
  1. Press the Windows key on your keyboard to display the taskbar if it isn't visible.The Windows key has the Windows logo on it.
  2. Right-click the Date/Time display on the taskbar and then choose Adjust Date/Time from the shortcut menu.
    The Date and Time dialog box appears.
  3. Click the Change Date and Time button.
    The Date and Time Settings dialog box appears.
  4. Enter a new time in the Time field.
    You can also use the up and down arrows next to that field to change the time.
  5. If you wish, click on a new date in the calendar display and then click OK.
    You can also change the time zone, if necessary.
  6. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
    If you don't want your computer to adjust for Daylight Saving Time, click Change Time Zone and click the Automatically Adjust Clock for Daylight Saving Time check box to turn this feature off.
  7. Click the Change Date and Time button.
  8. Enter a new time in the Time field.
  9. If you wish, click on a new date in the calendar display and then click OK.
  10. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
How doI set the clock
Setting the Time (Without Date Display) If your vehicle has an AM/FM base radio with a single CD player and preset buttons numbered one through six, the radio will have a clock button for setting the time. You can set the time by following these steps: 1. Press the clock button until the hour numbers begin flashing on the display. Press the clock button a second time and the minute numbers will begin flashing on the display. 2. While either the hour or the minute numbers are flashing, turn the tune knob, located on the upper right side of the radio, clockwise or counterclockwise to increase or decrease the time. Instead of using the tune knob, you can also press the SEEK, FWD (forward), or REV (reverse) buttons to adjust the time. 3. Press the clock button again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing will stop after five seconds and the current time displayed will be automatically set. To change the time default setting from 12 hour to 24 hour, press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H are displayed, press the pushbutton located under the desired option to select the default. Press the clock button again to apply the selected default, or let the screen time out. Setting the Time (With Date Display) If your vehicle has a radio with a single CD player or a CD with DVD player, the radio will have a clock button for setting the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the clock button and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) will appear on the display. 220 3. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. If your vehicle has a radio with a six-disc CD player, the radio will have a MENU button instead of the clock button to set the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the MENU button. Once the clock option is displayed. 3. Press the pushbutton located under that label. The HR, MIN, MM, DD, YYYY will appear on the display. 4. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the MENU button and then the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. 221 To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year, follow these instructions: 1. Press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) are displayed. 2. Press the pushbutton located under the desired option. 3. Press the clock or MENU button again to apply the selected default, or let the screen time out
Need to change time on my toshiba laptop pc
Windows 7 and below:
Start> Control Panel> Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Windows 8: Start> Type control and control panel will pop-up on the search list, click on that to open control panel>Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
2helpful
How do you change the clock on a 2009 Chevy cobalt.
Setting the Clock Without Date Display AM/FM Base Radio with a Single CD Player
To set the time:
  1. Turn the ignition key to ACC/ACCESSORY or ON/RUN. Press to turn the radio on.
  2. Press until the hour begins flashing on the display. Press a second time and the minute begins flashing on the display.
  3. While either the hour or the minute numbers are flashing, turn to increase or decrease the time.
  4. Press again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing stops after five seconds and the current time displayed is automatically set.
To change the time default setting from 12 hour to 24 hour, press the button until 12H or 24H is displayed. Once 12H or 24H is displayed, turn the knob to the desired option to select the setting. Press the button again to apply the setting, or let the screen time out.
With Date Display Radio with CD (MP3) and USB Port, and Radio with Single CD (MP3) Player
To set the time and date:
  2. Press and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) displays.
  3. Press the softkey located below any one of the tabs that you want to change.
  4. To increase the time or date do one of the following: • Press the softkey located below the selected tab. • Press SEEK, or FWD. • Turn clockwise.
  5. To decrease the time or date do one of the following: • Press SEEK or REV. • Turn counterclockwise.
The date does not automatically display. To see the date press while the radio is on. The date with display times out after a few seconds and goes back to the normal radio and time display.
To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year:
  1. Press and then the softkey located below the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) displays.
  2. Press the softkey located below the desired option.
  3. Press again to apply the selected default, or let the screen time out.
How do I change the date and time on my Meridian Business Set M5316?
To Change the Date and Time:
  1. Press
  2. Press the volume key until "Time and Date Set?" is shown on the display
  3. Press
  4. Enter the date using the format shown on the display (DDMMYY)
  5. Enter the current time based on the 24-hour clock
  6. Press to save the new time and date settings
  7. Press or to exit the programming mode
To Change the Display Fomat:
  1. Press
  2. Press the volume key until "Time and Date Format?" is shown on the display
  3. Press
  4. Press the volume key until the desired format is shown on the display
  5. Press to save the new setting
  6. Press or to exit the programming mode
Nov 16, 2010 • Cell Phones
12helpful
How do I change the time? How do I shut off the alarm?
http://assets.timex.com/user_guides/W163_M504/W163_M504_NA_EN.pdf
A. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode). Press MODE again
to enter TIME mode. SECONDS digits will flash.
B. Press ADJUST to set SECONDS to zero.
C. Press START/STOP to select MINUTES.
D. Press ADJUST to change.
E. Repeat to set HOURS, MONTH, DATE, and DAY of WEEK. Go through 12 hours to set AM
or PM.
F. Press MODE when done.
G. To display DATE from TIME display, press START/STOP.
H. With DATE displayed, press and hold START/STOP, then press ADJUST to change display
between DATE-MONTH and MONTH-DATE.
I. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12- and
24-hour format.
R Huff
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
1helpful
Xerox workcentre Pro 575 How do I change the time of day setting
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
    [01-31-2000]
  2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
    1. MM-DD-YYYY
    2. DD-MM-YYYY
    3. YYYY-MM-DD
  3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
    1. Numeric: displays the month with a number
    2. Name: displays an abbreviated month name.
  4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
    1. 24 hour
    2. 12 hour
  5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
    10:30 pm (or 22:30 pm if you chose the 24 hour format).
  6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
  7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
29helpful
EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Change the time
Depending on the software of the Norstar it is connected to, you would log in to the key system by using Feature **23646 and then follow it up with the administration password.
If this is a pre 1.0 system, i.e DR5.1 do the following. If not, go to the bottom and click on the link and find the manual for the system your phone is connected to. Generally the system coordinator guide will have what you are looking for.
Setting the date
Begin with the display showing
l.Sys speed dial
1. Press [NEXT] (second key from the top on right for a 7310) twice.
2. The display shows 3.Time and date.
3. Press [SHOW] (first key on the top on the right for a 7310)
The display shows the time, for example, Time 01:00.
- All times and dates must be entered using numerals. For
example, February would be entered as “2”.
- The time may be entered in either 12 or 24-hour format. If the
display is in English, and the hour entered is less than
thirteen, the display prompts you to specify “am” or “pm”.
Press [Show] This will open the time change function. Simple rule. If you want to modify a value, press [CHANGE] and you'll get a cursor. Once you're done with that entry, press [NEXT] to go to the Minutes, press [CHANGE] etc...
I have also included how to change the date below.
Press [Next].
The display shows the date, for example, Date 31 Mar 91.
4. Press CHANGE (softkey under screen). The display shows Year: 88.
5. Set the year.
a. Press CHANGE.
A cursor replaces the number on the display.
b. Enter the year using the dial pad.
For example, press a a to enter the year 1990. ?
c . Press [Next] The display shows the month, for example Month: 01.
6. Set the month.
a. Press [CHANGE]
b. Enter the month using the dial pad.
For example, press 02 to enter February.
c . Press [Next].
The display shows the day, for example Dar: 01.
7. Set the date.
a. Press CHANGE
: A cursor replaces the number on the display.
b.” Enter the date using the dial pad.
For example, press 14.
Top Meridian Lands Phones Experts
k24674
Are you a Meridian Lands Phone Expert? Answer questions, earn points and help others
