First guess is the camera has dirty heads. Suggestion is to run a head cleaner in your video camera. Regardless of the instructions on the head cleaner, I usually run the head-cleaner tape on "Play" for about 10 to 15 seconds, and then on "Record" another 10 to 15 seconds. Wait for 10 minutes before loading your playback tape. Try playing your tape again.
Also, check to be sure the tape is loaded properly and that the hatch closes securely and properly. A hastily loaded tape or an ill-fitting closure could cause the play function to stop.
If this does not solve the issue, it may be something in the play switch or in the playback mechanism that requires repair services. If the problem continues, I would recommend calling the Panasonic Company and speak with Tech support or Video Camera Repair. They may be able to tell you and estimate of what it would cost for the repair.
