everybody starts from being slow in typing,thats definitely ok,because you can eventually you will learn how to do it fast,the best advise that i could give you is do a typing test everyday, give time for it,atleast 30 minutes,it applies on me,ebcause now,somehow i can type faster than before,and still doing some practice to make my typing stills much better. here is the typing website that i am using,and it works for me,I hope you'lle try this,it will really help. www.freetypinggame.net try the games:) its a lot of it,you'll learn while enjoying. goodluck:)
just takes practice. also if one uses the correct hand layout, it can be very easy to train your brain to type faster. Check out http://www.freetypinggame.net/free-typing-lesson.asp
Setting up a rear end is not as easy as just bolting the parts into place. They should be set up with a special fixture and detailed measurements taken. If you take used gears and do not get them setup in the same relationship as on the previous vehicle, I can almost guarantee you that you will hear noise from them and they may not hold up long, especially on that type of car.
If you get new gears, for that type of vehicle you should get the "softer" strip only gears and have somebody who knows what they are doing to set them up.
You dont need to know your southbridge info or anything like that, you just need to know the socket type for the processor. If they make a processor for the socket type, then you can assume it is compatible.
theres a few things you can do to make your internet faster. First, you should know what type of internet you have. Dialup is going to be slow regardless. Also what browser are you using? Some would suggest that FireFox is much faster than a program like IE. Either way if your internet was previously faster try clearing your browsers cache. In ie click tools--> internet options -->delete --> delete all. In firefox click tools --> clear private data -->clear private data now. that should speed you up quite a bit.
hi welcome to fixya!
when it comes to internet, ADSL2 + router has really a big factor when in-terms of connections, because it helps to boost more speed. But the problem is it has nothing to do with the downloads I mean if your looking for a faster downloads it needs a high-speed bandwidth connection meaning it depends on the service provider where you attached to. And they have many types of a high-speed connection like: 512kbps, 1mbps, T1, 3mbps and etc. Just select on this type of connection from your ADSL provider and they would love to teach you the right configuration to have a faster download.
The reason CF COULD be faster is that it is a parallel connection (16bit IIRC) while SD/MMC is serial in nature. Now, assuming the INTERFACE were the limiting factor in the speed this could become significant. Unfortunately the interface is NOT the limit (in most cases), the limit is the actual fetching of data from the memory itself. Being Flash it is nowhere near as fast as some of the other types of memory we are used to. It is especially slow when being written to. Newer cards out there are faster then older ones, but in the end I doubt you would notice much if any difference between the speed of a CF versus an SD/MMC card
