Sony Playstation 3 (PS3) Console Logo
Posted on May 16, 2011
Hi our PS3 has no sound or picture. It does have the green power light on.
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on May 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
7681
Points
61
What is probably happening, is your PS3 is set for the wrong type of output. If you are using an HDMI cord, try switching to the AV cables that came with your PS3, and set your TV at the appropriate input to correspond with the AV hookups, and see if the picture works then.
If you are using the AV cables, it may have been set to HDMI accidentally. You need to use an HDMI cord, and hook the PS3 up to an HDMI compatible TV or monitor, and select the HDMI input. Once you get the picture working, go to Settings>Display Settings and set the display you wish to use.
The green light is on but no picture no sound
You could always try a system reset:
Starting with the PS3 off... Hold Power button on PS3 for 10 seconds. When you hear the second beep, it has been reset.
The game will freeze up, the whole screen turning green
Hi,of the multiple errors that can strike the PlayStation 3, you may one day have to fix the PS3 green light flashing problem. This issue is perhaps one of the most antagonizing for the average user. The unit appears to power up for about 3 seconds and then shuts down before the system has a chance to boot. When this happens you need to fix PS3 green light flashing problem in order to get your console working again.
Simple Ways To Repair PS3 Green Light Flashing At Home:
In order to fix PS3 green light flashing problem you're going to have to do some troubleshooting on your machine. The usual steps of unplugging everything and doing a hard reset apply. These are universal and advisable for any error on any console. If this doesn't work then you're going to have to go a bit deeper into your PlayStation.
Typically you get this error when something is not operating correctly inside the unit. This is different from a display or hardware errors, these still allow the console to be turned on. In the event you need to fix PS3 green light flashing problem chances are something is not working with your power supply.
If the PlayStation 3 detects a problem in the power supply or any other components that might cause severe damage it will not boot. If you want to fix PS3 green flashing light error you need to track down the faulty component and replace it. Do note that this is a safety feature designed to keep the console from overloading and requires some dis-assembly to fix. If you are uncomfortable disassembling your unit to fix PS3 green light flashing problem then you should send it in to get it fixed.
Learn how to fix green light error of PS3 with step by step instructions. We have actually prepared pictures and video guidance to fix all the ps3 problems in the best Ylod fix site.
Take care.
No sound on tv or from the actual ps3 unit, no picture.
be sure all cords are plugged in correctly and that the tv itself works if nothing helps and its not any of the cords you may need to get it looked at.
2helpful
2answers
Sound but no picture on PS3 using AV3/4
if it's happening with your ps2 and your ps3 on teh same tv, try it on a different tv. if you're getting sound but no picture, tehn it's something with your cables or your tv. restting the display setting should get your picture back up. make sure the system is in standby and then hold down teh power button. it will turn green and beep, then flash green and beep again. it should brng up a picture. if not, check your component cables, especailly if it works with the original cables.
I have have a playstation 3 and when I hooked it up to my tv as I normally do there is no picture or sound. I then tried switching to my HDMI cable with the same results. Yes, I made sure I set my tv input...
Try powering on you unit press and hold the power button and the eject button for 30 sec unti the power light begins to flash thats going to reset the setting of your ps3, and if that does not work i would rec> sending it out so sony if its still under warranty or exchanging it from where u bought it.
3helpful
2answers
PS3 IS ON, BUT NO PICTURE OR SOUND
no problem just turn system to standby mode and hold power on switch on system itself down for 10sec this will reset factory settings and picture should appear
2answers
No picture or sound
The "FROZEN VIDEO then PIXELATED VIDEO then NO VIDEO/" triad problem is all too common on the PS3. It results from gradual overheating of the RSX and/or CELL processor. The unleaded solder used in these machines XBOX360/PS3 often fails. In addition, if the ps3 also shuts down on its again own due to overheating. It is necessary to disassemble the unit and apply AS5 compound and shim the heatsinks to ensure proper contact between the heat sink and the processors.
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Picture goes to a lime green fuzz and then no piture or sound!
which AV connection are you using? HDMI or the cable supplied with the PS3, If using HDMI, you have to set the PS3 visual settings to HDMI, to do this, use the cable supplied with the PS3, and have the HDMI cable plugged in. Then while using the cables supplied with the PS3, switch the settings over to HDMI, then change the TV's input selector to your HDMI and confirm the settings changes. Hope it helps take care
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
