First of all you need to access the router. Use the
following:
Access the
D-Link Configuration Screen
Open your web
interface and type "http://192.168.0.1" into the address
bar, then hit "Enter" or "Return."
Use
"Admin" as the username and leave the password blank when the login
screen appears.
Click "OK."
You should now see the D-Link configuration screen.
Secondly, it would be better if only you could change the
settings of the router.
Set Up General Security
Change your
administrative password by clicking on the "Tools" tab and choosing
the "Admin" button. Enter a new password under the
"Administrator" heading. Confirm it, and click "Apply."
Disable the
wireless Local Area Network (LAN) if you don't need to use the wireless access
and you want to make sure no one else is able to access your network.
Under the
"Home" tab, choose "Wireless" and select the
"Off" option.
Last, is the
answer to your problem. Follow:
Enable
Wireless Encryption Protocol (WEP)
Locate the
"Home" tab in the D-Link Configuration screen, and click on the
"Wireless" button.
Use the
"Open System" button beside "Authentication."
Select the
"Enabled" button next to "WEP," and set the encryption key
to "128 bit."
Set the
"Key Type" to "ASCII" and choose a 13-digit password for
the "Key 1" field.
Write down
the password in a secure location.
Click "Apply."
