I had the water turned off, and started a wash load without turning water back on. Got F W error, turned water on, but nothing happening. Just noise like draining. Pressing cancel 2X doesn't work. Unplugging for a couple minutes doesn't clear cycle memory
Washing machine troubleshooting
http://www.acmehowto.com/howto/appliance/washer/diagwasher.php
You may have a problem with either your drive motor, motor control unit or main computer board (known as a CCU).
PS Check for the obvious first. Make sure the drive belt is still attached and not broken before getting too deep into troubleshooting everything else. NOTE: More commonly, this is an indication of a motor control unit failure.
Thanks, as it turns out, the extra rinse option light was on, and deselecting this allowed the washer to respond to the cancel/pause command
