Hi and welcome to FixYa, I am Kelly
Remove the muffler and clean out the exhaust port and screen. You will have to disassemble the muffler and clean off or replace the screen item 8 of this link:
http://www.partstree.com/parts/?lc=echo&mn=CS-330T++S%2FN%3A+C08611001001+-+C08611999999&dn=7946
Before taking the muffler apart... unhook the spark plug and just pull it though with the muffler removed. If it pulls normally you know you have found the problem.
If it still pulls hard...check the exhaust port of the cylinder head for 2 tiny holes (not screw holes) Some have them some don't depending upon the year of the saw. If you do find 2 small holes that appear clogged with carbon... do your best to clean them out.
Thanks for choosing FixYa,
Kelly
Testimonial: "TRIED SOULTION BUT THAT DIDN'T HELP."
The next step is to remove the carb and inspect the intake. You must clean both the intake and the exhaust . The final step is to remove the cylinder head and soak it in B-12 Chemtool or a similar solvent for about 12 hours along with cleaning the piston. There are grooves in the cylinder wall that port fuel between the crank case and the top of the cylinder. If those roughly 1/2 inch wide grooves get clogged you will have high compression. The Saw needs a serious head and cylinder cleaning and it should be fine. Until it has been cleaned you will have this problem. Anytime we have one come into the shop with this complaint we put the cylinder head, muffler and piston into a solvent tank for most of the day with flowing solvent. It works. Most home owners do not have solvent tanks that would be safe to use.
Kelly
Thank you, sounds like a trip to the repair shop.
