Question about Samsung Microwave Ovens
Have Samsung Trio Combi Microwave and it`s gone dead after a fuse blew in main fuse box. All other appliances ok but this is just dead. Fuse in plug ok!
I get a display of "--SE--" and get multiple beeps from my Samsung Trio microwave and the keyboard gets disabled.
Can some one tell me what this error code is and the solution please?
Thx
Posted on Sep 07, 2011
6ya staff
SOURCE:
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
Microwave ovens does not work, ooven is plugged up and electrical power is check at the receptacle. No power .
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 22, 2011 | Amana ALD10D Microwave Oven
Stopped working like it blew a fuse
Hope this helps.
Mar 08, 2011 | Sunbeam SMW777 Microwave Oven
I have power to the unit, I checked the fuse - OK - nothing working on unit
Hope this helps.
Mar 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My Advantium suddenly stopped working while using it. Acts as if it is unplugged. I checked the electric circuit and surgeprotector they are okay. It acts as if it blew a fuse, but I don.t know where...
Hope this helps.
Mar 02, 2011 | GE Advantium 120 Convection/Microwave Oven
Problem with the Bosch HME9760 / HME9750 800 Watts Microwave Oven Small pop when i went to open door, and now looks dead. 13amp main fuse all ok, so i assume its an internal thermal fuse or something...
Hope this helps.
Jan 06, 2011 | Bosch HME9760 Microwave Oven
Oven was running, suddenly stopped and now is completely dead. Power in plug is live. Fuse appears to be good.
Hope this helps.
Dec 29, 2010 | Whirlpool MH7140XF Microwave Oven
No power to microwave all ready checked fuse box and ok , changed microwave fuse ,and still no power and solutions it a whirlpool
the circuitry has probably gone bad, try plugging it into a different electrical outlet, but if that doesnt work, its probably dead. and it will be cheaper for you to replace than have serviced, unless its still under a warranty
Jan 15, 2010 | Magic Chef MCD1311ST Microwave Oven
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
Microwave Ovens Logo
281 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Ekse
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
