Question about Speed Queen AWS44NW Top Load Washer
The drum vibrates when the machine is on spin. I have moved the 4 springs onto the highest level but this has not helped.
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning- but you can see the springs. Shockers?)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 15, 2011
6ya staff
SOURCE:
My front loading Electrolux washer is vibrating during the spin cycle--so much so that it shakes the floor. The machine is level and sitting firmly on its drawer
there are 2 shocker on the drum like on a vehicle, these dampen the drum when spinning, when they stick or become damaged in any way the drum moves more. this makes the washer unstable and vibrate. also but more pressure on the springs that keep the drum up, they are easy to change, access to the springs is at the top the sockers are at the bottom.
May 30, 2017 | Electrolux Washing Machines
How do I balance drum?
Check the spring,s are adjusted and none have been disconnected .put some clothes in the bowel to check the machine
Apr 15, 2016 | LG WT1101CW 4.3 cu.ft. Ultra Large High...
Machine vibrating badly
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | Zanussi ZWF1430W Front Load Washer
Indesit WIB111 vibrates excessively on a spin It is level and is not overloaded. Sometimes the powder drawer vibrates out and the machine moves up to a foot!!
It sounds as if one or more of the drum supports, which are springs or shock absorbers, have become detached or are in some way damaged. You would need to take the back and top off the machine to check this. Otherwise you will have to call a service engineer.
Alternatively, if this is a brand new machine, the reason is that the transportation fixings have not been removed. These are typically two or more steel rods that hold the drum in place, and have to be removed when the machine is installed, and before it is used, If they are not removed there is no damping of vibration as the drum is not free to move on its flexible supports.
Mar 19, 2010 | Washing Machines
512S machine (top loader). Vibrates a lot when spinning, even while empty. Can't figure out why.
the large springs inside that keep the drum level could be snapped one of the leveling feet could be missing,mc may not be level in all plains
Jan 13, 2010 | Washing Machines
Need to balance washing machine drum
The drum should not need balancing, but the washer should be level in all directions. If the washer is level, but vibrates excessively during spin cycle, you may need to replace the springs. There is a set of suspension springs which act as shock absorbers. When these wear out the washer will bounce across the floor unless the clothes are 100% balanced in the washer.
Jul 29, 2009 | GE Washing Machines
Maytag performa PAV2300 Vibrates
HI!!! I used to work for maytag and this model vibrates and moves around ..we used to install skid pads so that it would not vibrate and move..also make sure that the unit is not off balance.. You should have 4 knobs underneath the unit so that you can adjust it..Good Luck..
Jan 04, 2009 | Maytag PAV2300 Top Load Washer
Washing machine
hope this helps, don't forget to rate me thanks
Try leveling the washer. Check for play along the diagonal corners of the washer cabinet by applying downward pressure. If there is any play at all, the washer will shake during spin and the legs must be leveled.
You have br put your heavy washer on a floor that would be condemned for structural weakness if a building inspector saw it. Try placing reinforcing pads or pieces of plywood on the floor under the washer.
On Maytag top loaders: worn damper pads.
On Whirlpool/Kenmore direct-drive machines: worn snubber pad
Dec 28, 2008 | Washing Machines
Speed Queen AWS44NW Top Load Washer Logo
116 people viewed this question
Top Speed Queen Washing Machines Experts
Poppa Maddo
Poppa Maddo
Marvin
Marvin
Paul Bade
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
