Bosch Axxis+ WFR 2460 Front Load Washer Logo
Posted on May 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code F18 - Bosch Axxis+ WFR 2460 Front Load Washer
ZJ Limited
Level 3:
  • Master 17,989 Answers
  • Posted on May 14, 2011
ZJ Limited
Master
Level 3:
Answers
17989
Questions
0
Helped
14459397
Points
60858
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
Ryan Pries
Level 2:
Sergeant:
  • Expert 257 Answers
Ryan Pries
Expert
Level 2:
Sergeant:
Answers
257
Questions
0
Helped
69403
Points
791
F18 is a drainage fault.
The appliance has a set time to drain if it doesn't drain within that time F18 appears in display
Diver 1
Whirlpool AWM 8085 Washing Machine. What problem IS error code F18 please?
Question edited for clarity
Whirlpool error F18 Error code F18 indicates there's too much foam in the drum. Thankfully, this problem is easy to solve. Unload the drum and run a wash cycle without soap. This removes excess foam.
Jan 30, 2023
The most common errors of Whirlpool washing machines
coolblue.nl https://www.coolblue.nl > advice > help-most-common-e...
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
Sump hose has fallen off Unplug tilt machine back have a look underside to check also could be the soap dispenser hose Hole in it.This rubs away on side of machine 5yrs old.
1helpful
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Hotpoint WMD960 F18 error code
I had the F18 fault.Nothing much worked except drain pump.
Simple solution for me was:
1)disconnect power 2)take off top of machine(2screws at rear) 3)locate the connector which fits on the rear of the main led display panel.4) Pull it off, squirt switch cleaner and replace with plenty of wiggling! 5) Put it back together and start washing !
Steve Brighton
2helpful
Error message F18 what does that mean? i lost the manual... michael
F18 (usually!) means there's some issue with drainage. If the washer doesn't drain properly within a specific amount of time, you'll get the F18 error. A common fix is to remove the panel covering your drain and examine it for any sort of debris that may be obstructing it - plastic, lint, loose change, etc.
4helpful
What is error code F18 please?
F18 means the filter is blocked. Look around for a propeller shaped part - it should be able to spin freely. If not, remove the debris so that it is unblocked. Good luck!
4helpful
3answers
Hotpoint Ultima WD865. Showing Error Code F-18. Please advise.
hi, i turned on my wd865 machine and it starts fine and sounds the same but its displayinf f 18. but it doesnt continue the wash in the usual way . what does f18 mean ? please help :)
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
