There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
thanks how do i know if balancing shocks are bad? if i push tub to side is it supposed to automatically return to center? thanks again
Yes and they everything should be relatively even. Many times I have found on completely snapped.
i took the front panel off and there are 6 springs attached to bottom of tub. they all seem to be functioning, does this mean that balancing is not the issue?
belt and motor are spinning at what seems to be full speed, if i manually turn tub it starts to move slowly
Sorry that indicates that your drive clutch is bad and needs to be replaced.
