If the unit is running all the time and is not freezing everything then open the back fiberboard panel and clean out the coils in the back. Check to make sure the condenser cooling fan is running also. If the compressor is running and the condenser fan is not running there is a problem with the condenser fan. The compressor, condenser and evaporator fans all should be running at the same time. the condenser fan can be stuck... have dry bearings... of simply has failed. Before removing the back cover... touch the chassis were the doors close... it should be warm but not VERY warm to the touch. If it is VERY warm to the touch... for sure you have a problem with the condensor fan.
Since you did not say anything other than the fridge is working whit out stop, I have to assume at this point that the evaporator fan is running in the freezer compartment just fine.
I really need to know:
1. Is there ice in the back of the freezer compartment?
2. Is the evaporator fan running?
3. Is the condenser fan running?
4. Are the condenser coils clean?
One of the above has a problem... you just need to identify which one.
Thanks for choosing FixYa,
Kelly
