Car Audio & Video Logo
Anonymous Posted on May 14, 2011
My Alpine iDA-X001 radio is not powering up. I checked the power to the unit. At the power pin on the 16 pin adapter I am getting 14 volts DC. Once the adapter is plugged into the unit it drops to 3-4 volts DC. I tried running it straight off of the battery, and through a switch that I have installed. Neither option allowed the system to power up.
Anonymous
Level 3:
Master:
  • Master 752 Answers
  • Posted on May 14, 2011
Anonymous
Master
Level 3:
Master:
Answers
752
Questions
Helped
172143
Points
2278
Adaptor for what
  • Anonymous May 14, 2011
    The 16 pin adapter for the wiring harness.
Grundig 750 'Satellit' radio. Works fine on batteries, new power supply AC-DC the radio shuts off or displays LOW on screen.
On the rear where the power adapter plugs in, it should show in input voltage and polarity. Check the power supply output voltage with a volt meter. Generally, it is the sum total of all the batteries, so it if takes 4xAA @1.5 volt batteries the voltage would be 6 volts DC. It sounds like it is faulty.
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
Only distortion..
Check your power adapter. This unit REQUIRES a 9 volt AC adapter, NOT a DC one... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound generation with a DC adapter. This is a common problem as people try to run these on a DC adapter.
Here is a link:
http://cgi.ebay.com/AC-POWER-ADAPTER-Alesis-HR16-SR16-D4-DM5-/380178938839
Cant play ipod after iphone upgrade to ios4.2.1
Check with Alpine for and update for you radio
5helpful
DC error message
tonite while driving on a bumpy road i had the dc error right after a big bump.
according to user manual,
one of your speakers connector got lose and is touching the metal body of the car giving a shortcut
-> check your speakers wiring
Alpine ida-x001 volume is low even if stereo is turned all the way up only when ipod is plugged in on ipod setting.Radio (AM/FM) is normal volume (louder)..How can I fix this?
Most newer car receivers have a feature named something like "level balancing" in which you can adjust the relative loudness of each input (Tuner, CD, AUX, IPOD). Check you owner's manual for a similar function.
Also, are you or can you turn the level of the ipod itself up a bit?
7helpful
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
My son had an Alpine IDA-X001 and a Sirius Connect Vehicle Tuner installed in his 2005 Pontiac Grand Prix yesterday. The Sirius is not activated at this time. He is experiancing problems with his car...
I believed so that something is draining power in your circuit. I suggest that you must activate the SIrius now and check together with the Alpine if it help fix the problem. It is maybe it turns out to be that the Sirius resist the flow of power when it is not activated.
Alpine IDA-x100 and KCE-300BT
Hi
what you need to do is to start off make sure both units are powered from the same point you will see why below. Make sure you connect the Audio Interrupt out lead (pink/black) from the 300bt to the x001 INT IN pink/black wire
Go to general settings turn off the int mute setting, (you proberly have it turned off already the reason your not seeing it) try resetting it using the small button behind the face plate. This should allow you to see the int mute setting. Go to the bluetooth settings and select adaptor. Disconnect power to both units. ( you will need to re apply power to both units at the same time) after around 10mins. when you re-connect the power make sure ALL bluetooth units around the car are turned off. You should now have success in pairing the phone and having the X001 recognise the 300 bt.
Konka model 1508U 12 v dc ADAPRTER PORT
Most devices are Negative to Earth, Chassis and Positive to the Center Pin on the "Adapter". So probably any 12 - 14 Volt say 4Amp well regulated, or Switch Mode power Supply probably would power your unit.. If you don't know the exact voltage Start at about 6 Volts and work up until it works correctly.. I often use a switchable power Supply to find the right voltage and then get a fixed supply to suit.
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
