Hi, Here is one site that I recommend
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Replacing the turntable motor.
The motor assembly is fixed to the base
of the oven usually with two screws and access i obtained by removing
the inspection plate directly beneath the motor. It is usally a plug
in synchronus motor that revolves at a few revs per minute but the
plastic cogs in the motors gear box fail and the motor assembly must
be replaced. They are fairly inexpensive and obtainable usually from
a domestic appliance repair shop.
If you feel confident,
disconnect it from the mains power, remove anything in the cavity and
turn it upside down if it is a tabletop model, a little more
complicated if it is built in!
Remove the inspection plate and
disconnect the motor. Remove the motor and go and get a new one. Re
fit it and put the microwave back in its position. Plug it back in,
with the turntable and plate. Put a cup of water on the plate inside
of the oven and heat for 20 seconds to check the plate goes
round.
Hope this helps.
