SOURCE: can motorola h375 bluetooth headset pair with verizon lg voyager?
i don t have the instruction i lost them
SOURCE: Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
SOURCE: My LG EnV3 was dropped and now is white when the
Dropping it may have dislodged one of the internal components. I would bring it to the Verizon store and see if they can fix it or give you a new phone.
