If it is under warranty i advice you give it for service as this is a pretty complicated procedure to get it fixed.
E45 error message sometimes means that the lens is misaligned, This error is also may be due to failure of the control system.
To solve this:
You can remove
battery and card replace battery and while switching on tap the lens
hood on your hands so as to disengage any dirt or mechanism being
struck.
Use some air to blow between the lens to dislodge any sand
particles struck inside. If none of these works then you can think of
taking consensus with the service center. You must keep in mind that to open the camera without good experience is not recommended and might tamper the delicate unit so best option is to Contact
Kodak to see if your camera is still under warranty, otherwise contact
any Kodak Cameras service provider, your problem will be solved.
Its very unlikely the lens is "out of alignment" this just
cant happen unless its been dropped or bashed, in which case it may be
broken.
Hope this helps. (remember to rate and comment this answer).
