Ricoh Aficio 450 Copier Logo
Posted on May 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My copier is ricoh aficio 650 during it self test and worming time the message appear sc101 - 00
Anonymous
Level 2:
  • Expert 263 Answers
  • Posted on May 13, 2011
Anonymous
Expert
Level 2:
Answers
263
Questions
0
Helped
132757
Points
586
That message is related to the scanner.
Probably the scanner lamp is dirty and the white bar under the glass.
You have to remove the glass and clean it with a dry cloth.
See you
3answers
Ricoh Aficio SP C232S. How to solve Error Code SC 829 on Ricoh 232-0 please?
Question edited for clarity and correct order, 'make model problem'.
Error Codes > Ricoh > AP828 > Code SC829
PrintCopy .info https://printcopy.info > brand=Ricoh > code=SC829
Ricoh AP828 · Code: SC829 · Description: Self-diagnosis error: optional RAM [XXXX]: Detailed error code [0302] Composition error (Slot 0) The result of checking ...
Missing: 232 ‎' Must include: 232
2answers
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Ricoh Aficio 2232C Error Message SC393-02
I had the same problem after transit of copier. Try removing the yellow developer unit and give it a good shake. You may need to do it with the other units too.
Ricoh Aficio Sc 122
The scanner home position sensor
does not detect the home position
during initialization.
Causes:
Scanner I/O board or SBU defective
• Scanner motor defective
• Harness between scanner I/O board
and scanner motor disconnected
• Scanner HP sensor defective
• Harness between SBU and HP sensor
disconnected
• Scanner wire, timing belt, pulley, or
carriage defective
3helpful
Ricoh 1515 is locked up with error message SC:820 code 612. How do I fix the problem
820 Self-diagnostic error: CPU
Symptom:
• An unexpected exception or
interruption occurs during the self-
diagnostic test.
• An error is detected in the MBU.
Possible Cause:
• Defective controller
• Defective firmware
• Loose MBU jumper
Code 820
MBU error (The jumper is loose.)
Set the jumper (on the MBU) correctly.
The following codes are displayed:
• SC: 820
• code: 612
• detail: 40000000
1helpful
What does the error C390 on an aficio 1013 photocopier mean
TD sensor error test value abnormal the TD sensor output voltage is less than 0.5v or more than 5.0v after 10 consecutive times during copying the possible cause willbe TD sensor defective,TD sensor not connected or connector damaged ,poor connection between the TD sensor and the I/o board (IOB),I/O board (IOB)defective ,toner supply defective
1helpful
Ricoh aficio 1045 error e990 please help it
This is a software performance error; However it is most often caused by a deteriorating drum unit. There is no exact solution, but 9 times out of 10, a new drum unit, and fresh developer will solve it.
Outside of that, it is likely a board problem -possibly BICU
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
