How do you open the band of my new movado watch?
It probibly is a tri-fold clasp or a "hiding clasp" When you look at you watch can you see a clasp? If not you just need to pull from the middle if the back of the band. One end will open to the left another will open to the right. Don't be afraid to pull on it, that probibly is the main problem your having. Movado makes a solid band that can take some punishment
i
SOURCE: Adjusting Band Size on a Movado Amorosa Watch
there are little pins holding them in place pop them ou and add or delete couple links.
SOURCE: Need a pressure pin for a Movado lady's watch
I thought the purpose here was for you to help me - not the other way around.
SOURCE: Broken Watch band
you probably just need a pin to secure the links back together. an authorized Movado retailer will have the tension or screw pins to put the band back together. They can also order additional links if needed. you can find a local retailer on www.movado.com
SOURCE: I cannot put the new
Hi, On most watches they have two pins that you have to remove with a small flat screw driver.
These pins are spring loaded so watch out. You will need some patence to do this. Good luck
