Acer Aspire One  PC Notebook Logo
Posted on May 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My screen doesn't work, it is sleeping. What can I do ? After I took a rest my screen dit nothing. Whatever I trie, it doesn.t light up.
Anonymous
Level 2:
  • Expert 69 Answers
  • Posted on May 12, 2011
Anonymous
Expert
Level 2:
Answers
69
Questions
0
Helped
22300
Points
218
Try restarting your computer, If it happens again, try to find a pattern in the problem. If you can't restart, hold down the power button for a few seconds to do a forced shutdown.
My Vaio doesn't go to sleep/hibernate when closing the lid
Maybe the little sensor or pin that sticks up and is pushed in when you close the lid is broken and the software doesn't realize the lid has been closed.
My mp3 isn't turning on even thought it is fully charged but plays music when plugged into USB
There is a Problem with the Mp3 Battery its not Charging get it Replaced!
I just added a LCD monitor to my eMachines ET1331G desktop computer. Everything worked fine until I left it on for a day. The computer went into sleep mode and now I can't get it to wake up. I've trie
You should be able to just press the main system unit power button to wake up your 'sleeping' computer which will then resume your Windows desktop and bring you back to the Login panel if you have a password set for your account.
1helpful
Toshiba 61PJ7UA, turn itself off and will not start. Power on light is red but when you hit the remote to turn TV on it clicks but dosent turn on(no green light). I have the circuit boards (particularly...
HERE'S THE ANSWER TO YOUR PROBLEM:
I think the problem has nothing to do with your TV. I bet the culprit lies on the setting of your remote control. Maybe you set your remote into a sleep mode. When a TV has set into a sleep mode. It's power on light is still red but doesn't work. So all you've got to do is keep pressing the sleep button. After a few presses, it will definitely work. And, you can now enjoy your day watching TV. Thanks.
1helpful
I have old pc that worked for too long but after i bought new screen ( HP L1950 ) every time it says montior is going to sleep and some time it freezes forever and some time it says no signal but after i...
* check com cable all thru the video card socket,also check you video graphic card pci if its inserted properly,try to clean it first.
* might your pc is in Hibernate or Sleep mode
A power management mode that conserves power by powering down the system. In hibernate mode the current state of the system is saved to the hard drive, and the system will power down. When a user turns the system power back on, the saved information is read from the hard disk, restoring the last used settings. Hibernate mode is similar to sleep mode, however in sleep mode the power cannot be shut off.
go to control panel > power management and change or default the settings you wish.
I got my acer and the power light comes on but the screen is black
This happens with my Acer Laptop too. Make sure the computer is plugged in to a power source and try a forced restart. If that doesn't work, try using the sleep command to but the computer to sleep while the screen is black but the power is on. The computer's power light should shut down, and you should be able to go out of sleep mode by pressing spacebar.
My screen is not working at all,, i master rest it then i took off the battery multiple times also my sim card and nothing works!
are the lights on the laptop burning when you turn it on and is the hard drive spinning ? If not, it's more likely you have a problem with the power. maybe the power supply is broken, is there a light on this that you can check ? If it's broken the battery won't charge and nothing works.
How much to fix ipod touch screen and where
Good morning, afternoon, evening or night; whatever time of day you receive this. You want to know how much to fix the touch screen and where to fix it? I want this solution to benefit you as much as possible. Having to pay for someone to fix your iPod touch screen should be your last result. I'm tell you some options you can try that may save you a few dollars and having someone to fix the iPod touch screen. I don't if this is the problem, but the touch screen may be locked. Automatically, the iPod touch locks when there has been no activity for a certain amount of time. To unlock the touch screen, press and hold the Home button or the On/Off/Sleep/Wake button which is located at the top of your device, and then drag the slider. If you want to set the amount of time before Auto-Lock activates, press Settings, General, Auto-Lock; then set your preferred time. If that doesn't fix the problem, you can try a system reset. To do this, press and hold the Home and On/Off/Sleep/Wake buttons together for approximately 10 seconds until the Apple logo appears on your screen. If this doesn't work, you can take your iPod Touch to your local Apple Retail store and have an Apple technician work on it for you. There will be a fee for diagnostic services. You can also contact Apple Technical Support or Online Service Assistant. For more contact information, go to this website (http://www.apple.com/support/contact/). I hope the problem is just a screen lock up and if you have to get a repair or replacement, it won't burn a hole in your pocket. Thank you for choosing FixYa as your one-stop solution spot for your problems and requests. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
