AT&T Nokia 6555 Cell Phone - Black Logo
Posted on May 12, 2011
Why is it no display appear in main display it was just black but there is a display in mini display?
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Jun 29, 2011
Anonymous
Contributor
Level 1:
Answers
22
Questions
Helped
2717
Points
23
Your main screen has gone bad or a wire is loose
tip
Nokia N97 mini Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia N97 mini mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N97 mini mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia N97 mini without any sim card.
2 - Don't bother as to what is displayed on your Nokia N97 mini.
3 - Compose #pw+CODE+1#.
4 - The Nokia N97 mini would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N97 mini mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N97 mini
Each Nokia N97 mini mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia N97 mini mobile phone from the site http://www.unlock-zone.com/
Black screen problem
it appears there is a high level of data corruption on your computer's hard drive sadly you must reinstall the windows OS however i do recommend using Ubuntu to access your files while in live cd mode by clicking try ubuntu or use mini-XP (a mini version of windows xp) and use an external drive or mega.nz (mega.nz for free can store your files up to fiffty gigabytes)
Android xperia guide
  • Press the center button on your X10 Mini Pro to launch the phone's main menu. Tap on the "Settings" option to enter the Settings menu.
  • 2Tap on the "Wireless Controls" heading to manage your phone's wireless connections. Tap on the "Wi-fi" or "Bluetooth" heading to enable your phone's Wi-Fi or Bluetooth radio.
  • 3Tap the "Wi-Fi Settings" option, and then tap "Add" to connect to a wireless network. Or tap the "Bluetooth" settings and then "Discoverable" to begin pairing your phone with a Bluetooth device. Press the phone's right button to return to the main menu.
  • 4Tap on the "Sounds and Display" option. Tap on the "Silent Mode" option to mute your phone's ring or tap the "Phone Vibrate" option to set your phone to vibrate. Tap on the "Phone Ringtone" option to select a ringtone for your phone.
  • 5Tap on the "Brightness" option to adjust the amount of light your X10 Mini Pro's display will emit. Tap "Screen Timeout" to set the amount of time your phone's display will stay lit after being inactive. Press the phone's right button to return to the main menu.
  • 6Tap on the "Applications" heading. Tap on the "Manage Applications" option to manage the programs that appears in your X10 Mini Pro's main menu. Tap on a program, and then select the "Delete" option to remove the program from your phone. To add a new program, tap on the "Market" icon in the main m
    sincerely. G-d bless you
    ernesto cuadra
    managua,nicaragua.c.a
  • 0helpful
    2answers
    Mini display is backwards
    I had this problem once, i just turned the phone off and took the battery out for about 5 min, and when i turned it back on it was back to normal
    Phone won't turn on properly
    hi Miss_Pink03
    most likely those symptoms appears when the phone Flesx cable is faulty
    What is the phone flex cable??
    its the electronic stuff that connects the keypad to the Main and Mini Display
    u most replace it and its not an easy task though
    plz do rate this post
    My Main Display is OK. It is my Mini Display which is broken.
    I’m surprised that instead of getting a response to my question posted yesterday in your Forum I’m getting an offer to switch to your Premium Assistance Plan.
    Nevertheless, I partially solved the problem. I found out that I need just the small outer LCD for Nokia 6103. I already found it on eBay.
    But the main question remains:
    I need instructions, manual or pictures how to replace a broken outer Mini Display for Nokia 6103.
    Thank you in advance
    False color with Dell E151FPp and Mac Mini
    a big issue with this..does the mac mini have the drivers for that monitor? only one way to find out..
    www.mac.com has support and drivers, no?
    Top AT&T Cell Phones Experts
    ZJ Limited
    ZJ Limited
    Sean Wright
    Sean Wright
    ADMIN Andrew
    ADMIN Andrew
    Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
