Look under the stool for the water valve coming out of the wall and turn it clockwise till it stops turning. This will turn the water off. Flush the stool and get all the water out of the tank as possible.
Look where the water hose goes to the bottom of the stool tank. You will have to take the hose loose with a pair off big water pump pliers or crescent wrench.
After taking the hose loose from the stool, there will be a big nut just above where you took the hose off the tank. You will have to look under the tank to see this nut. Use the same wrench to take this nut loose. You may have to hold on to the old valve.
Once you get this nut off, the valve will be loose from the tank, and you will have a little water leak out of the tank which you can catch with a big towel.
You should be home free from here. Put the new one back in reverse order.
