Welcome to Fixya. The security key can be found when you access the wireless settings page of the router. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password isblank.
Click on Security under Wireless and look for the Security Key or Network Key (Passphrase)
If you have questions please let me know. Thanks for using Fixya.
SOURCE: network key for router.
In onder to obtain this information you need a computer that has internet connection through the router, if you have a main computer that is wired through the router then use that computer if not try to hardwire the laptop to the router(plug it to any of the number ports that say ethernet/lan). Access the setup page of the router by typing 192.168.2.1(deafult IP address of the router) on the address bar of your browser(i.e. Internet Explorer, Firefox, Safari), type admin for the username and leave the password blank. Go to the Wireless Settings/Configuration tab of the router and verify the security mode(WEP or WPA)
SOURCE: Network Security Key for Belkin D5D9630-4
I think it is 1234567890123,WEP,Shared key.I'm not sure though.
SOURCE: Forgot my security password (network key)I need to
Logon to your router from your computer using your browser and going to http://192.168.1.2/. If it wants a username, the default username is blank and the default password is either blank or "password".
The Belkin management tool will come up. From there, go into your security and look to see if your passphrase is visible. If it is, you're good to go. If not, you can change it on that page save it and close out.
Don't forget to change the passphrase on any wireless devices you are using connected to the Belkin wireless router.
SOURCE: need network key for belkin g+ router 802.11g
if you own the router and you don't know the network key or forgot it.
you need to reset your router, please check the intructions that came with it. if you haven't change the admin password (which is by deafult blank) go into the admin page and change or delete the network password doing something similar to this
if you don't have or can't remember the admin password you need to restore the router to defaults to reconfigure it
if you don't own the router and don't know the network key you need to ask the router owner for the key or use a program to hack into the router signal and attempt to figure the key out. (not recommended as it is ilegal)
SOURCE: I lost my network security
Connect with your existing computer (either wired or wireless)
(note if you can't get into the router you can do a factory reset, HOWEVER you need to make sure you have all the broadband user account settings to attempt this)
hope this helps
Please take the time to rate this answer.
Many Thanks Don.
