Master
- Posted on May 11, 2011
Re: I need a code for RCA remote RCR311STR for a...
In order for the 4 component universal remote to control your TV, you must program it with the TV code that matches your TV. These instructions explain the preferred method of programming the remote-the Direct Entry method.
- Manually turn on the TV.
- Locate the enclosed TV Code List. Find your brand of TV.
- Press and hold the CODE SEARCH key until the indicator light illuminates. Then release the CODE SEARCH key.
- Press and release the TV key. The indicator light blinks and then remains lit.
- Use the number keys to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
- Aim the remote at your TV and press the ON•OFF key. If your TV turns off, you have found the correct code.
- Write the code down for future reference.
- If your TV doesn't turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
Program for VCR: In order for the 4 component universal remote to control your VCR, you must program it with the code that matches your VCR. These instructions explain the preferred method of programming the remote-the Direct Entry method.
- Manually turn on the VCR.
- Locate the enclosed VCR Code List. Find your brand in the VCR Codes.
- Press and release the VCR key. The indicator light blinks and then remains lit.
- Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
- Aim the remote at your VCR. Press the ON•OFF key. If your VCR turns off, you have found the correct code.
- If your VCR does not turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
