Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
I am trring to pair my bluetooth hbm-550 but it is not working a paired it with my phone but when i out in the pass code it is incorrect ......what else can i do
SOURCE: i need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
HIH
SOURCE: I need help connecting my blue tooth to my phone device
Hello
If you are referring to connecting your pone to your blue tooth device(dongle pluged into your computer?), you activate the blue tooth on your phone, plug the device into youre computer and right click on the blue tooth icon in the bottom right corner which will appear after a few seconds.
Click on ad device, your device will then search for other blue tooth devices.
Your phone must then appear.
double click on your phone, then you will be asked to enter a password. Enter anything and then next.
Your phone should now ask for a password then enter it.
Now the devices are paired.
Now just use the send via Blue Tooth function.
Hope you find this usefull.
