You will need a Wifi access point to connect your Sylvania Netbook using Win CE 6 to the internet. Some cellphones can act as "Wifi access points" but most cellphone network vendors will want you to pay $10USD a month to use that feature.
Free Wifi access points include McDonalds, your local public library, your church and other resturants. I have also found that all major interstate rest areas in IOWA have free wifi.
There are several lists of Free Wifi hotspots on the internet. I like this community effort listing: http://www.wififreespot.com/
The SN comes with a short wifi guide and there is a video as well as a step-by-step Wifi guide at www.digtialgadgets.com
Tom M.
There may be many reasons for this. Please check the following things one by one.
1. If you have another known good laptop then try it with your wi-fi router. See if the wi-fi router is able to connect to the internet
2. If you don't have another laptop then use an ethernet cable (RJ45) cable to connect to the wi-fi router. See if this helps.
3. While connected with the wi-fi router see if you can access the router. open any internet browser and type 192.168.0.0. you should get the router page. If you don't get then you have to configure the router first.
4. Check the internet settings of your browser. There will be "internet options" or similar in the menu of your browser. Click that. In the GUI you will get "connections" tab. Click that and select the proper wi-fi setup.
