Hi Ron:
Here's what I would do;
- UNPLUG THE SAW
- Use a screwdriver or needle nose pliers to get the broken bit out while holding the retaining clip in the release position.
you can use needle nose pliers pull the hood release cable on inside car where cable broke from handle.needle nose pliers will help you enough to pull cable to open hood so you can replace fix hood release handle and cable.
you'll be ok using needle nose pliers and a tin of wd 40 lube. but don't go too crazy with the stuff as it doesn't really like playing with terminals. but in this case use the straw attachment, for in between the outer casing of the bulb an the inner casing of the socket. leave for a couple of minutes then use the needle nose pliers, grip the casing of the bulb, inner and outer, push the bulb in with the pliers and then twist.
What kind of back do you have? Does the back have 5 little notches on it? If it does it is a screw-off back. With this kind you can use a needle-nose pliers and turn it counter-clockwise and it will come off. If it dosn't have the notches, looaround the back and the watch casing and look for a little lipp or open notched area and take a sharp strong knife and pry it up. If this is a expensive watch, some have a seal that holds the back in place and dosn't really have a notche .Use a razor blade to start it , and then a sharp knife to open compleatly. If you still have problems, please let me know. Good Luck!!
