If this is a new installation or someone has removed the lever and put it back, take the lever off.
There should be an plastic insert with grooves and a stop on it, which allows the lever to only go so far.This is removable. The insert acts as a stop to prevent scalding. you should be able to pull it out and reinstall in with the stop more toward the left allowing the lever to go more toward the hot side. Hopefully this helps out.
