Roper RAS8445KQ Top Load Washer Logo
Posted on May 10, 2011
RR.COMRoper Model RTW444OXQO IN THE RINSE CYCLE THE WATER LEVEL IS ONLY 6 INCHES FOR A LARGE LOAD. iS THIS NORMAL?
5 Related Answers
Anonymous
  • 1073 Answers
  • Posted on Apr 20, 2008
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Terry Schneider
  • 177 Answers
  • Posted on Oct 04, 2008
SOURCE: 28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Anonymous
  • 566 Answers
  • Posted on Oct 23, 2008
SOURCE: front loading washer bangs and thumps during spin cycle
hi may i suggest you remove the top cover of machine and check the drum mountings(rubber) and the spring/s that are connected to the bracket on drum have not broken /come off just one other thing ? when machine was installed was the bracket under the top cover removed b4 connecting and using machine ? this bracket is for security/stability of drum whilst being transported see instruction book ? it is not the first time iv'e encountered this bracket not being removed by customer diy installation worth checking? best wishes
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Feb 12, 2009
SOURCE: LG Tromm WM2277HW Water level to low
this is normal the pic are all photo shop water you clothes are clean right?
Anonymous
  • 6 Answers
  • Posted on May 08, 2009
SOURCE: Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
1helpful
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
1helpful
2answers
I have an admiral washer atw4475xq can you adjust the water level on the rinse cycle
Pulled this together from a couple of Solutions & added some helpful tips I found as I successfully changed the rinse cycle water level!
ATW4475XQ - Admirial Water Saver washer - Adjust Rinse cycle water level
The rinse cycle water level can be adjusted. Unplug the machines power.
You can youtube a video on how to remove the top control panel, its just 2 screws on the back of it,
phillips head. Swing the control panel up, and find something to support it so you have both hands free.
(http://www.youtube.com/watch?v=MYn0_qCFdec)
You'll see a clear plastic tube coming up from the back rear like 3/8 in diameter, to a "T"
connection. The one that goes to the left, thats the wash water level switch it connects to. The one you
can adjust, large, medium, small, from the front of the panel . The other off the T goes to the rinse
water level switch. There is not a knob to adjust it. But if you look at the bottom of the lever
mechanism/cam pickups of both switchs, you will see that they are the same. Rotate the wash load size
(knob on outside of control panel) from small to large, back to small, notice how the mechanism changes?
The rinse water level swtich acts the same way, although it is only a 2 position switch, small and
large. Once you watch the wash level mechanism move from rotating it back and forth a few times, you
should be able to see how to rotate that same mechanism on the rinse switch 1 click. It will click into
place, there are only 2 positions as I said and from the factory its in small, so once it "clicks in"
dont go any further. I did mine with a very small screw driver without removing the rinse switch.
Once you get that hidden switch turned to the other position, put it back together, fire it up and now
your rinse is the large level, all the time.
NOTE: There is a white plunger out of the end of each switch with a screw located in place. Dont mess
with the screw or that plunger. As you adjust the lever mechanism/cam this adjusts the amount of that
plunger sticking out, which changes the pressure pickup for water level.
2answers
The level of water in the rinse cycle is extremely low to the point that the clothes are not rinsed. Why is there such a large differential between the level of water in the wash and rinse cycle? How can...
Low water pressure or bad inlet valve, or clogged screens in fill hoses, check flow with hoses disconected these will be the causes! check hot and cold fills than check warm, any differnt all setting work?
My GE washing machine drains the water after the rinse cycle but does not start spinning. It just sits with the water pump running and does nothing. This doesn't happen with every load but seems to be...
Most likely the tube from the tub to the water level switch is full of "gunk" so the washer still thinks there is water in the machine, and therefore will not spin. Take the front panel off by pushing in the retaining clips at the top seam between the front panel and the washer top. Pull the thin hose off the left side of the tub and clean it out. (or cut off an inch or so, but you can only get away with that once or twice). To help prevent re-occurance, every two or three months you can fill the washer to the lowest level with hot water and several cups of bleach (no clothes) and run it through a cycle. Rinse at the ex-large setting to make sure all traces of bleach are gone before doing another load of laundry.
Can't see water leverage
water level needs to be brought up alittle on your amount of level as in small med large loads...
4helpful
2answers
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Lent on clothes
Not familiar with this model but it sounds like too little water is being used (small, medium, large load) or a rinse cycle is being skipped.
With enough water and normal rinse cycles, the lint should be suspended and pumped down the drain. If this is happening with every load, then it isn't working properly.
4helpful
Lg wm2277h has low water level
The water level is very low on front load machines. (Below the bottom of the door) While the washer is running, push and hold the "spin speed" and "soil level" buttons at the time. Display should be between 230 and 255.(normal) If you do this while the machine is filling, you will see the numbers change. This machine only uses about 12 gallons of water for an entire cycle, vs. about 45 for some top loading machines. THIS IS NORMAL ! The machine will adjust the amount of water based on the type and volume of clothes in your washer. On a large load, you will see wet clothes, but no water sloshing around. PS. Because the machine uses so little water, make sure you use only one tablespoon of HE detergent (and only one teaspoon of fabric softner if you use it). This is very important.
If this info was helpful, please rate it as a "FixYa". Thanks.
10helpful
2answers
Top Roper Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
