SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: What remote control code does the Onkyo TX-SR304 use?
From: http://www.comcast.com/remotes/universal.html - only worked for me when I had AUX setup with 30135
Unlocking Volume Control For A Single Device (Individual Volume Unlock):
Now, after you select a device that has volume unlocked (e.g., AUX), pressing VOL , VOL-, or MUTE will control the device's volume only in its own mode.
If desired, repeat steps I to 3 (of this section) for each device that you want volume to be unlocked.
SOURCE: need codes for universal electronics remote that will oporate tx-sr606receiver
I have the same problem and from what I've read elsewhere there is not a cheap and easy solution. From what I gather, simple remotes (like what you get w/ your set top box) that use manufacturer's codes for programming treat "on" and "off" as a simple toggle. That means they fire out a singal signal which is supposed to simply change the state of the device from off to on or vice versa. The Onkyo apparently uses different signals for on and off. Because of this we will need to get a "learning remote" which can be programmed to provide a separate signal for any desired function. These tend to be much more expensive which is why they don't just give them out with your set top box. Right now I'm still fiddling with separate remotes until I break down and drop the bucks for the special remote.
SOURCE: Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
