Question about Visual Land V-Motion Pro MP3 Player
The player will not power on or off jammed on a screen and does nothing
    Master:
  • 195 Answers
It looks like a hardware related problem, i think it is caused by a defective chip or something like that. its hard to give any other information because in these cases it needs inspection of somebody with experience in mp3 player repair
Posted on May 10, 2011
6ya staff
SOURCE:
How do I remove stuck DVD?
If this is a combo unit the first thing you have to do is remove that dvd from inside the player. Open up the unit and do the deed. THEN see what happens. Often when the player gets jammed or whatever, it will render the rest of the set useless until the hassle is removed. In this case get that disk outta there.
If still nothing disconnect the power line that feeds the dvd to see if that has any effect on overall tv operation.
Sep 05, 2015 | Sylvania Televison & Video
Pioneer DVD player DV-220v-K not responding to Open Drawer command
This is a mechanical problem and will only get worse, caused by gear ware timing issues, or jamming.
Apr 19, 2012 | Pioneer Televison & Video
My creative zen 4gb video player will not turn on
well i think you might have disconnected the power button or maybe the soldering has been disconnected. the factory would be best to fix it.
Nov 28, 2009 | Audio Players & Recorders
CD jammed inside player
Remover the player's cover. That will give you access to the player's internals and therefore also the CDs. That is the only way to go about a problem like the one you are facing.
Disconnect the player from the mains supply before doing this.
Good luck.
Nov 09, 2009 | Technics SA-AX530 Receiver
Display jammed
Pioneer has a recall on the ribbon cable that controls the screen! Go to there website.
Jun 18, 2009 | Pioneer AVIC-N2 Car DVD Player
My power acoustik 8960 touch screen does not respond
return it...it will start jamming when loading a disc and the fan will start to grind soon.  it is a bad unit..like all 3 I have HAD!!!!!
Feb 18, 2009 | Power Acoustik PTID-8960 Car Video Player
Screen is blank
Check to see if the little button that the screen closes down on (which turns off the screen and only the screen) is stuck, or jammed under the little hole that it comes up.  This button is about the size of a pin on most DVD Players, and is located very close to the screen on either side.
Jan 03, 2008 | Mintek MDP-1030 Portable DVD Player
Dvd Jammed
There should be a tiny hole that you can get a paper clip through on your DVD this hole leads to a manual release mechanism that should open the DVD drawer. I hope this helps
Sep 10, 2007 | Shinco SDP-1250 Portable DVD Player with...
It won't open or close
There is a plasic cover that goes over the gear behind the screen on the left side. Take a look at that, it might be jammed in the gear prventing it from open or close.
Jan 26, 2007 | Panasonic CQ-VD7500U Car DVD Player
Visual Land V-Motion Pro MP3 Player Logo
107 people viewed this question
Top Visual Land Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Visual Land Audio Player and Recorder Expert? Answer questions, earn points and help others
