Incase iPhone 3 & 3GS Perforated Snap Case (Vivid Turquoise) Logo
Posted on May 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi ! I am trying to synch my iphone to my computer but i keep getting a error message 13019
Anonymous
Level 2:
Scholar:
  • Expert 76 Answers
  • Posted on May 10, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
76
Questions
0
Helped
16943
Points
268
Easiest way i have found to resolve the issue is go into itunes while phone is plugged in. you will have a list of tabs across, summery, info, ringtones, music. select music and where it displays sync music unselect that and hit apply in the bottom right (dont worry your music should be saved on the computer) once the sync is complete re check the music sync option. ive noticed this to work 95% of the time
hope this helps
tip
How tro fix a Error 13019 during syncing your ipod touch with itunes
Select the iPhone or iPod touch in iTunes under Devices.
Click the Music tab and deselect the Sync Music option.
Click Apply and then click Sync.
After the sync is complete, reselect the Sync Music option.
If the Error 13019 occurs while syncing content other than music (applications, podcasts, and so on), then perform the same steps above but uncheck the content that stops syncing with Error 13019.
If the steps above do not resolve the issue, attempt to sync an empty iTunes music library to the device while logged in as a new admin user
on May 02, 2010 • Computers & Internet
Error code 13019
look at the article on this forum it should help you http://support.apple.com/kb/TS2830
Can't sync iphone to computer. Error (13019) occurred.
There are various reasons for this issue like below shows.
The problems to cause "Can't sync iphone to computer. Error (13019) occurred" can be various. You can refer to the following aspects to check and fix this issue.
1. Maybe your iTunes version is outdated and you need to update it to the latest version to ensure it to work normally.
2. Maybe there is something wrong with the USB cord you are using. You can change a new cable to have a try.
3. Maybe your computer system needs to update. You can check out your Windows system and access to new updates to handle this issue.
4. Maybe your iPhone system version needs to be updated. You can go to "General" tab on iPhone to check for iOS updating and follow the on-screen instructions to make it.
If you fail to settle "Can't sync iphone to computer. Error (13019) occurred" by trying the 4 methods shown above, you can continue to read the below instruction to help you to realize your goal.
Check: How to Fix iTunes Not Recognizing iPhone in Windows 10
I cant sync my iphone. is says error 13019.
Anne,
You can visit this article from Apple's KB. Click here.
2answers
I keep trying to sync my iphone to itunes, but it keeps saying an unknown error(13019)? What do I do?
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2helpful
Iphone not sybcing with itunes,error pops up with #13019
error (13019).is iPhone Sync Error if you uncheck ‘sync music’ box then sync your iphone it will sync correctly It is a problem that got to do with the Voice Memos although its not limited to voice memos if the problem persists try unchecking the sync voice memo
1helpful
IPhone 3gs not syncing, I keep getting Error 13019. What to do?
I don't have an iphone 3gs, but my friend had the same problem what we did was to restore it and the problem was gone.
I think it should do the trick for you also.
Good luck.
I phone error number 13019
Untick the box to unsync all music on your iphone and then sync it again. Problem solved in a matter of seconds.
Top Incase Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you an Incase Cell Phone Expert? Answer questions, earn points and help others
