Apex Digital AT2702 27" TV Logo
Posted on May 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dont remember the code for the remote to my television
Anonymous
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on May 18, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
5
Helped
422
Points
Am using a converter box, it was working unit the electrical power went out in our area, for about 5 to 10 mins and then it was back on. I turn the tv on got a blue screen, tired to disconnect, chg to 3 or 4, scan channels, nothing screen still blue. I go and buy another converter box from Best Buy, still couldn't get the tv up and running, I call Best buy tec and they tried different things, reset, disconnect all etc, still blue. What else can I do. I hate to buy anther tv.
Level 3:
Top Expert:
  • Apex Digital Master 76,851 Answers
  • Posted on May 10, 2011
Apex Digital Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986871
Points
237762
Hello
Try with these codes. These codes are of universal remote control with Apex Digital.
015 226 037
How do i get my LM-1750 remote control to operate my sylvania 6427FF television
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
2answers
Loewe tv problem
Hi Dean Cooper, Go to This link, and let me know if you solved your problem.
remember to rate me*
20helpful
3answers
Devant remote control code
my devant remote control cant function. how can i use it? Model ER-31951D
2answers
Remote me PSm kese off karte hai
i remember this kind is problem is found in BPL televisions. either you get a remote of same code (code is written on remote face) with PSM key. by that key you can put off the psm display. or you can open remote carefully because remote has one or two screws and locks on the sides. then you will find a empty button below key pad which is not used by any key. (no key is touching that button.) you place any key on it while cells are in & press that key & see the PSM is off.
The nursing home my mother is in has a Toshiba 13A24 TV in ;her room. The can't find the remote and I wanted to get her a universal and be able to set it up for her What do you advise
Hello, a Universal remote should have the codes already set for the Toshiba so it shouldnt be too hard, just follow the instructions. Just remember that some of the cheaper remotes dont have all the codes.so make sure you get a good quality one,she deserves it!
2helpful
I locked my tv because of kids and now i dont remember the passcode
I can only assume that you are not the kids trying to get into the set.
You must have the original Mitsubishi remote control to perform this operation on the set. Look on the remote for a button that is labeled QV (Quick View), if you have this button on the remote then we can press on. Go to the selected channel or input that is asking for the unlock code. When it asks for the code, press the QV button: Holding it down press the number 9 and release. This will unlock the set for this instance. To remove the code I suggest that you go through the setup menu and find the code lock and when it asks for the code use the QV+9 trick again to turn it off from the main menu.
If you do not have the original Mitsubishi remote you will not be able to try this trick. You will have to order a replacement remote from 1-800-REMOTES or www.remotes.com.
Once you have the replacement remote you can unlock the television and be back on your way.
If you have any more quesitons please feel free to reply to this post.
I hope that this helps you with your television lock issues and as always, Thank you for using FixYa.
asnowman
My lg television model 42lc2db dont know the code tried sky they dont know it, can you help.
Please Follow the steps below
TV
RED + SELECT ( hold these down until it flashes twice)
TV
0056
Try the volume if this works then press the SELECT button. If this does not work the volume then press TV again and then try the volume again. Repeat this step until the volume works then remember to press the SELECT button to save the code.
If for any reason this does not work remove the battery cover from the remote. You should see on there ''REV 4,6,8 you may have an older remote in which case you will need to get a different REV remote.
Hope this sorts you out. If so please leave a thumbs up for me Please.
Cheers
Little Dish Fitter
JVC code to set my remote
Brand codes for universal remotes are determined by the remote control manufacturer, so there's not really "a code for JVC" that anyone could tell you. You could try looking on the remote manufacturer's website to see if they have the information available. Or you could simply purchase another remote, and you'd have a fresh set of instructions.
4helpful
Panasonic quintrix F TV
Hi, i have bought a new Sky remote, but i dont remember the code of TV. please would you be able to help?
2answers
Code
Dont worry about programming a universal remote for use with only one device like a Tv because after you program it. only a few functions like the basic functions of the remote will work. for example the "Power", channels keys, and volumn. you will not be able to make that remote work for any other features, like PIP, menu, aspect, input, etc. I suggest getting the original remote control. ReplacementRemotes.com usually has a suitible replacement or the original manufactures remote that comes with your TV.
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
