Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
Posted on May 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does a CE error code on an Electrolux refrigerator (model EW26SS65GS) mean?
Deborah
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Oct 18, 2015
Deborah
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
9589
Points
9
My fridge was having the same problem with CE being displayed, light and touch selector not working. With the assistance of one of my sons, we tilted the fridge back slightly and removed the control circuit board. Two of the three 470 u F capacitors were toast. My son drilled out the plastic brads holding the circuit board in the pan, then removed all three of the 470 u F capacitors. He soldered 3 new capacitors in place (0.59 cents each) and used 4 small screws/nuts to secure the board in place. After looking at the capacitors, he said a power surge had caused the damage. We went right out and bought a surge protector for the fridge. My fridge works perfectly now. While protecting tvs and computer from surges, I had never even thought of using a surge protector for the more costly fridge! Hope this helps someone else avoid an shamefully expensive parts replacement.
  • Uwe H
    Uwe H Oct 05, 2016
    Same error on uk JLAFFS2008 and one 470 uF fried. Don't have the soldering skills of your son but panel was forgiving ;-) and FF works just fine. Thanks for posting! £0.49p instead of £120 for whole panel :). Will also follow the plug recommendation, makes sense.
Steven Clarke
Level 2:
Sergeant:
  • Expert 222 Answers
  • Posted on Feb 15, 2013
Steven Clarke
Expert
Level 2:
Sergeant:
Answers
222
Questions
0
Helped
141541
Points
567
Communication error you need a new power board (under the front of the unit) and a new user interface board. you must replace both at the same time ...... trust me replace both together.
  • Raul ilardo
    Raul ilardo Dec 07, 2014
    I have the same problem with my refrigerator. How do I access to both boards?
1 Related Answer
Anonymous
  • Posted on Nov 04, 2008
SOURCE: LG refrigerator error code
Had the same problem + a weird noise, which turned out to be ice build up on the blower fan. Unplugged overnight and then opened the lower back panel. There is a small fan that blows over some small coils at the bottom of the box. There is also a drip pan that should be "full" of water. I sponged out the drip pan, put the panel back on and then plugged back in. Works great.
Model EW23CS65GS. What does 5b error code indicate?
Hello Dwaine, thank you for your inquiry!
I understand that your Electrolux refrigerator is displaying an error code of 5b and you would like to know if this is a main board failure. I am not showing 5b as a valid error code; however, there is an error code of Sb. This means Sabbath mode and you can turn it off by pressing "-" on the freezer temp side and "+" on the fridge temp side. This should turn off the Sabbath mode.
I have also included a link to the manual for the refrigerator EW23CS65GS. On page 13 you will see Sabbath mode feature and the instructions on how to disable it. I hope this information is helpful to you. -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Anderson/241868900en.pdf
What does EI28BS36IS3 blinking lights mean
Are all of the lights flashing or is it flashing a code like Sy EF or Sy CE? If so the ef would indicate the evaporator fan circuit has a problem, and if it is SY CE it would indicate a communication error.
Electrolux refrig will not dispense water from door
Did you cherck to see if someone turned off the water to the unit?
Why am I receiving a CE error on my Electrolux refrigerator?
Thank you for your inquiry, friend!
"CE" stands for communication failure on your Electrolux refrigerator. You could be seeing an issue within your main control board or user interface board. I would suggest having a technician come out to properly repair your appliance. -Matt
CE Error on both sides
Good Afternoon Friend,
I understand you are receiving a "CE" error code on both displays on your Electrolux refrigerator, model# EI26SS55GS. This "CE" code means there is some type of communication error. I suggest resetting your refrigerator, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to press the "Mute Sounds" button to turn the alarm off. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
7helpful
2answers
CE error code on electrolux refrigerator
Hello Alan Rapp - Typically error code CE indications a communication error at power up. You would need to contact a professional to check the wiring between the main control board and user interface board. Technician will need to move forward accurately and either part will possibly need replacing.
2helpful
CE alarm panel display Electrolux side by side refridgerator
Hello Roy Avila - Typically error code CE indications a communication error at power up. You would need to contact a professional to check the wiring between the main control board and user interface board. Technician will need to move forward accurately and either part will possibly need replacing.
1helpful
Error code CE
"CE" error mean you have a communication error at power up. Check wiring between Main Control Board and User Interface Board. Replace User Interface Board. If problem still exist, replace Main Control Board. Good luck
1helpful
Ce is displayed on my electrolux refridgeator
CE= Communication Error. This is a generic error code. Contact a professional to diagnose the unit completely.
Top Electrolux Refrigerators Experts
ZJ Limited
ZJ Limited
vince
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
