I have an RCA Bookshelf stereo with a 5-Disc Changer. The main problem with my stereo is the disc changer itself. Whenever I push the open/close button on my remote control or on the stereo, it keeps getting stuck. Sometimes, it doesn't completely open or close. I always have to use my hands to make the disc changer open and close. What is the problem?
If it plays the same disc without issues, you have a mechanical(or the electronics powering the motors and such) problem. For more information, please visit my website at audioserviceclinic.com. Thank you.
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Look for a reset button at the back or may be at the front head of the cd changer.It is a very small 1mm hole.If you find it insert a paperclip in it,press and hold it for 1 min.This will reset the unit.If you still face the problem then just unplug all the cords of the changer for 1 hour and then plug it back in.
this is done by a belt drive. i have seen the belts get old and slip. try to gently pull the door open as you hit eject. If you get it to open and find that it will not fully open or close without assistance this is the problem.
sometimes the timing cam that is just below the tray, it is a plastic bar with teeth along its edge will get out of sync with the tray, draw it to the opossite end and put the player back together and the players tray assembly will re sync itself...i hope this helps you
i have the same exact problem with mine. what i did was manually pull open the cd deck, stop the disk carousel from spninning by holding it still, then push the deck closed. the cd deck will no longer work, but at least it stops spinning. the auxiliary works fine and so does the radio.
