The disk that came with your system is a recovery disk only. You will need a full installation disk from your local retailer or you can match the OS from your old HDD and use the serial key on the side/back of your machine. If you just wanted more space, install both drives and set the original one as the boot drive. the new drive, if properly installed (refer to your hdd instructions and jumper settings) you will see the second drive under "My Computer" as additional storage
GOOD LUCK AND PLEASE RATE THIS POST AS FIXYA!!
