Sometimes, Due to viruses or hidden data in the memory card, the handset is unable to format the memory card. so if u format it from a pc, using a card reader, your mem card will surely get formatted easily.. But if there is some technical problem in formating, download HP DRIVE KEY BOOT UTILITY It repairs up and formats the corrupted data and your memory card will be ready to use again .. Happy formatting !
Memory not formatted
What do you mean by Memory card not formatted operation failed? Cannot format that not formatted memory card since you do get much crucial data left inside? Or the formatting process cannot be completed there? OK! No matter what type of situations you are in now, do not overwrite this memory card and firstly rescue your memory card data with memory card not formatted error recovery software. And then, format this memory card to see whether it is still workable.
Of course, the computer CHKDSK tool also can help you test whether this memory card is still healthy.
Memory card is not formatted then it is the critical issue for the card users. It generally happens when memory card has severe problem. In this condition formatting memory card manually stopped. To fix this issue just run the process of Photo recovery Mac.
SOURCE: I can't able to format my memory card..it shows
Make sure your card has only the amount of gigabytes that the phone indicates. It will not format if you are trying to use a card with more memory than the phone allows.
SOURCE: 3110 Cellular Phone: memory card not formatted, operation failed...
This is a problem due to the memory card IC.The IC has to be replaced .Better contact service centre.If you are familiar with Mobile Circuits you can follow the instruction in the following diagarm.this will solve the problem
SOURCE: when iam opening memory card
Hi, problem can solved.When a memory card says formatted operation failed,it means the memory has been affected with VIRUSin it,thats why it's not given you access to get into it.
What you will need to do is to format it.
You can use your phone to format the memory card by going to the option of the memory card and click on format memory card.
Also you can use a PC to format the memory card by using a memory card reader. insert the memory card inside the card reader and connect to your PC, click on my computer, you will seethe memory card icon displayed, right click on the mouse for options to come up, and click on format memory card and you done.
Note: When trying to format and it does not format the memory card, that means the VIRUS that affected the memory has damaged it totally, that means you will have to get a replacement memory card.
Thanks for using fixya....
