SOURCE: Creator 2010 crashes when first
This program needs some specific System Configuration, I hope you've all the minimum listed below:
Which Service Pack of Windows XP is installed? This program doesn't support Windows XP Sp1 and Sp2. If you have all these, then please try to uninstall and reinstall the program, Update the Direct X. Restart your computer and let me know the result.
Awaiting.
SOURCE: recently bought & installed Roxio 2011 on
If you are getting the error at startup, roxio service might not started or disabled. What you can try to do is to enable all roxio service. refer to the steps below.
- click start > run
- type services.msc
- look for all roxio service i.e roxwatch.db
- double click it then select the startup type to automatic
- save the changes then restart computer
Cheers . . .
SOURCE: I had to replace my
NOTE: If frequently using your computer for recording and editing
audio and video, defragmenting your hard drive on regular basis
(about once a month) is recommended.
If you purchased your video card separately, then you will need to
find out your make and model and go to the video card manufacturer's
website to download.
Windows 7 and Vista: Click on Start -> type "msconfig" in the Search field and press Enter on your keyboard.)
Screen resolution refers to the clarity of the text and images on your
screen. At higher resolutions, items appear sharper. They also appear
smaller, so more items fit on the screen. At lower resolutions, fewer
items fit on the screen, but they are larger and easier to see. At very
low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution,
and 1600 × 1200 is a higher one. CRT monitors generally display a
resolution of 800 × 600 or 1024 × 768. LCD monitors can better support
the higher resolutions.
Whether you can increase your screen resolution depends on the size and
capability of your monitor and the type of video card you have.
Text and images are sharper and smaller at high screen resolutions
Text is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
Open Display Settings by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
Under Resolution, move the slider to the resolution you want, and then click Apply.
