Yes, you just need to connect the Airport to the modem. That way, the Airport will fetch the internet connection and distribute it to all your WiFi enabled device. You don't need any other hardware. You just need to configure the airport using your Mac computer.
Here's a quick setup guide from Apple.com:
Setup Airport Extreme
Try turning off Airport. Your computer may be finding a wireless network and automatically switching to it, and getting an intermittent signal. Just a guess, but for a good ethernet connection you want to disable the Airport searching feature anyway. Open the System Preferences application, select "Network" and right on the top left of the resulting window there's a pretty big button that will either say "Turn Airport On" or "Turn Airport Off" - just turn it off if it's not already ...
Hope this helps!
For help with Public Address Systems see my new How To Video, available as a DVD at www.whamuniversal.com
Speak with your internet provider, it sounds to me that the apple people didnt know what the problem was without getting down and dirtyy with it so they replaced it hoping for an easy fix. Seems to me that either the internet signal is being interrupted between the isp and your home .. or the motorola modem is having problems. I have never been a fan of motorola modems to begin with. Also the rentals u get from cable companies are used.. and typically subpar bottom of the line equipment that fail often. IF you think you will be using cable internet for years to come, purchase a linksys modem, as it is you are paying $3-5 a month for the rental of the modem. But I digress, speak with your isp and see if they cant troubleshoot the problem.. if 2 airports are having the same problem the chances of it being the airport... slim to none. good luck with all of this post again if nothing changes.
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Throw the device out of the window, the apple folks are terrible and liers they mislead us into buying this device and it is not working with most Vistas.
well imac G4's don't have built in airport (wireless internet) included as usual with apple its another item you must buy an airport extreme card then hook it up to an airport base station another item to buy via wireless internet then hook you airport extreme base station up to your modem via ethernet. whew ok now sync the airport base station to your imac using airport set up application then select your network and type your WEP password and viol internet in about 1 hour if your lucky hope this helped my fingers hurt now LOL.
