Http://www.whatismyip.com/ copy your ip to url address bar, then enter. if it ask you password and user name, just put nothing in username and admin in password. if it doesn't ask you anything, you might have to look at your manual.
You have to reset the router and login with default password.
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
