SOURCE: Panasonic PT-47wx53, No power, 3 Blinks
Panasonic PT53WX42F with same problem. 3 blinks after power on for a few seconds, no picture or sound. Solution: replaced two convergence ICs (STK392-XXX) located on the large green printed circuit board. ICs are very large and screwed into two large heat sinks and soldered to board. Cost is approximately $6 each. Easy to replace if careful. May be able to access solder joints on bottom of board by removing screen on bottom of cabinet or simply remove 4 screws that anchor plastic holder to cabinet and tilt up. I did not disconnect any inter-board connections. Remove heat sink screws. Desolder using suction bulb or solder sucker. Works great. Finish off with solderwick braid if necessary to clear holes. 40 watt iron is enough do not apply too much heat to damage board lands. Remove IC. Clean heat sink by scraping away white heat sync compound. Apply generous amount of heat sync compound to new IC and coat evenly. Align and insert new IC holes, resolder with thin resin core solder being careful not bridge lands. Refasten to heat sink. Clean board and inspect for good joints and no bridging. Refasten plastic board holder. Carefully clean projection lenses while back is off tv. Power up and it should be fixed. Parts are obtainable on-line. Solder tools and board cleaner are available at Radio Shack or on-line also. I spent $20 on parts and supplies. This is not hard just a bit tedious. You can do it.
I also followed Tim Smith's instructions and my TV is now working. The only thing is that as an engineer I realized that the Panasonic TV has a poor way to dissipate the heat which is probably what caused the problem to begin with so I went to Fry's electronics and bought 3 computer cooling fans and adapted them on the back of the TV grid. They are very quiet and they have their own power supply so they do not interfere with the TV operation. In addition next to the same parts that Smith mentioned above I found some resistor that changed from light blue to brownish color this is a sign of overheating. I ordered the resitor directly from Panasonic and replaced them also. So look for some bad resistors.
By the way the service manual cost me $10 and I highly recommend you to get it if you are going to fix it yourself.
Thanks Smith !
SOURCE: Panasonic TH50PH10 Turn off Automatically
Hi, if your plasma flashes 10 times it means that there is a problem with the sustain driver. This could be an intermittent problem, such as when the set heats up. It should be returned to the dealer as it is under warranty.
SOURCE: TH-42PX80U JUST TURNED ITSELF OFF
The 7 blinks indicates that a failure has happened within the Y main and the upper and lower y drive panels. I recommend you taking it in to a Service center for and evaluation.
SOURCE: tv keeps switching itself off
When that happens - try unplugging the tv for a few minuets & plug it back in.. Sometimes it will reset its self.. Or it could be a bad sercut or maybe a falty power suply.. Electronics is usually process of illimination - unfortunately..
