Texas Instruments TI-83 Plus Calculator Logo
Posted on May 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the metric equivalent of 31/2"
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on May 07, 2011
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428318
Points
622693
One inch is exactly 0.0254 meters, so 31/2 inches is 15.5 inches which is 0.3937 meters. If you mean 3-and-a-half inches, that's 0.0889 meters.
1helpful
Just bought a Hyundai HHC2GNK nailer, and the nails jam seemingly every second nail. Very frustrating! Any hints on how to solve this problem?
Assuming the nailer is in good order the problem is likely with the nails - the type, style, quality of nail you are using might not suit the nailer.
Some nails are poorly made and although I haven't personally measured them I suspect some nails purporting to be a particular gauge are either under or over the size. If they are imported, for instance, from a country using the metric system, they will probably be produced from sheet steel of a convenient metric dimension that is a near equivalent size, but not an exact match - 1.2 mm sheet is a tad smaller than 18 gauge while 1.3 mm is midway between 17 and 18 gauge.
Just a theory you understand.
Some nailers will be a little more roomy than others, especially those that have been worn in.
In addition it is equally possible the nailer was designed for metric nails but exporting to a country where metric nails would be unobtainable the manufacturer specifies a near equivalent, sometimes opting for the higher number and sometimes for the lower number - we see this a lot with imported clothes and shoes.
2answers
What size/type socket do I need to remove spark plug on my Ryobi 2300 generator. I've tried 1/2 thru 13/16 and none fit.
i cross referenced the spark plug (LD A7RTC)
and got the NGK equivalent:
SKU: #CR7HS
ITEM : # NGK7223
BRAND : NGK
Then got the specs off the NGK site
NGK 7223 CR7HS Nickel Spark Plug
It should be a 5/8" (16mm) spark plug socket.
200 ml is ?? cc
Within the metric system 1 ml (millilitre) of volume is equivalent to 1 cc (cubic centimetre) of volume,
Therefore 200 ml = 200 cc
Trust this helps, regards Alan
Mar 04, 2015 • Motorcycles
How do I change km to miles
The kilometre is unit of length in the metric system equivalent to one thousand metres.
1Km is equivalent to 0.6214 miles.
Feb 06, 2013 • Motorcycles
5000 pounds to metric tons
Hi jess49...
5,000 pounds is equivalent to 2.27 metric tons Please take time to rate me
Sep 23, 2011 • Home
Don't have a tool to get the bleeder lose? What is used to get this loose to bleed the breaks?
It's usually a 3/8 ths wrench or the metric equivalent. If you're very careful you can use a vice grip pliers to loosen it.
Rear hub nut on a2003 hyundai elantra
Very wild guess. I replaced the bearings in my 2003, and was looking in my tool box. I came across a 1 1/4" socket that I purchased around the same time, but I realize that it should be the metric equivalent of this, so it probably did not fit perfectly. Metric conversion would be 31.75 mm.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
