I just need to know how to completly clean the bottom of my imperial fryer
Are you talking about the actual burners? They make a L shaped brush that you can use to get around the burners themselves, and a quick tip is to clean the fryer warm.... Once you heat up a griddle or fryer, the cleaning gets substantially easier. They also make either liquid or dry powder cleaning additives, which also help with the cleaning... Once cleaned, make sure you rinse all the soap residue out of the frypot, as that will help to quickly break down your oil, once that new oil is heated up. Another tip is to ony turn the temperature up to 325, not 350, as that also helps to break down your oil. Keep in mind, no matter what yu do, your fryer will never look clean again.... Even the clean, used ones look alittle used after some use and never look shiny new again. If you need any of the cleaning solutions, I do sell them and would be happy to ship some to you... Our individual packets of liquid Mr. Muscle cleaning solutions run $1.95 each and for a 30-40 lb fryer, you need two per cleaning. The directions says to drain oil out and rinse to clean out loose soils, fill w/'water to oil fill line, and get water boiling. You add the Mr. Muscle while filling w/water.... Boil at about 225 temperature for 10-30 minutes. (225 degrees keeps it from boiling over). While it's boiling, gently use a fryer brush or scraper to remove baked on soils. You can also buy the powder version, which is $11.95 for a 9lb jug... Fryer brushes are $24.95 and can withstand alittle of the high heat.... I stock all of these items and can ship to you, if desired. Try this anyway, whereever you end up buying your products and this should work for you...This is how we clean the dirty deep fryers we get in and we've never had any trouble. Our phone number is 888-542-5959, and we are Restaurant Equipment Outlet, Cincinnati, Ohio. We sell new/used equipment, furniture, smallwares, just about anything you need for a food service business.
Thanks, Susan
