Use the parking break bypass procedure, and there is no need to even hook up the break wire. The parking brake bypass procedure is as follows:
1: Go into AM/FM mode 2: Hit "setup" on the remote control 3: Enter 543210 on the remote, listening for the beep for each number entered 4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen. 5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen. 6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Hit Setup On Remote. Select Language. Get Remote And Hit 5,4,3,2,1,0. Listen For Beeps. Touch “Hammer/Screwdriver” Logo. Select Brake Override Switch To Brake Override “ON” Now Hit Setup On Remote.
